Raider12 13 #1 Posted October 9, 2011 I have a 1990 520H that has the swept front axle and I would like to change it to the straight axle. I never plan to use a 60" deck or a front loader. But I do need to use a snow plow on this machine. Does anyone know if this would be a simple swap? Do the straight axles have a 1" spindle and use the same tie rods? Thanks for any input. Share this post Link to post Share on other sites
Rollerman 290 #2 Posted October 9, 2011 You would have to swap out the axle, spindles, wheels, tie rods, & lower steering shaft to do the conversion. The 520 parts are pretty unique to that model & heavy duty. I'm not to familiar with the early model 520's (pre 60" deck) that had the straight axle...that mightg be another swap option? I'm sure someone here would want your swept forward axe & would jump at the chance to swap parts with you? I'd say keep the forward swept axle on your 520 & look for or have a snowplow extention fabricated for it. Or use an early long frame plow & bracket. (used on the 953/1054/GT14) They went straight back & didn't have the bend in them like the later ones do that put the plow frame parallel with the tractor frame. The early style bracket set the plow frame just ahead of the axle center line instead of at bottom center. The 1st 520H I owned had that setup on it. Share this post Link to post Share on other sites
wallfish 18,628 #3 Posted October 9, 2011 I'm sure someone here would want your swept forward axe & would jump at the chance to swap parts with you? Yeah, I'm one of them Share this post Link to post Share on other sites
Rollerman 290 #4 Posted October 9, 2011 I would be too, but think reworking the plow or replaceing it would be a better option. :thumbs2: Share this post Link to post Share on other sites
wallfish 18,628 #5 Posted October 9, 2011 I agree 100% Share this post Link to post Share on other sites
sorekiwi 761 #6 Posted October 11, 2011 I have a D200 snow plow up here Denver that I might be interested in parting with. I havent tried it on my 520, but have been told that it will fit. I'm not too far from you if you want to have a look. Share this post Link to post Share on other sites
SAM58 31 #7 Posted October 11, 2011 It would be A LOT easier to just find a snow blade extension. You should keep it original if you ever plan on selling it. :thumbs2: Share this post Link to post Share on other sites
sned 15 #8 Posted October 11, 2011 You would seriously devalue the tractor if you get rid of the stock front end. But I would gladly give you every single part you need if you would give that junky forward swept. :thumbs2: Share this post Link to post Share on other sites
Raider12 13 #9 Posted October 11, 2011 You would seriously devalue the tractor if you get rid of the stock front end. But I would gladly give you every single part you need if you would give that junky forward swept. Im thinking! A buddy of mine wants this tractor and all he will ever use it for will to mow and plow snow. He would never take advantage of the swept front axle. But I do consider the work involved compared to making an extension for blade. Share this post Link to post Share on other sites
312Hydro 474 #10 Posted October 11, 2011 This is what you need for the swept axle 520-Extension .Shouldn't be hard to have fabricated. Only pic I could find. It lengthens the frame 6" to clear the wheels. Share this post Link to post Share on other sites
jusjeepn 59 #11 Posted October 11, 2011 Here's the one I made for mine. The extension for length The extension for lift and a few more Share this post Link to post Share on other sites
312Hydro 474 #12 Posted October 11, 2011 THAT's what I'm talkin' about! Great job on that fabrication,Jusjeepn! On a lighter note,here's food for thought- Share this post Link to post Share on other sites
