AlB 0 #1 Posted October 8, 2011 So I've check the seat relay, pto safety switch, I've replaced all fuses, one of which was toast. I have juice to both sides of the coil. I've got the blinking oil light which I assume goes off upon starting. Where do I look now? Share this post Link to post Share on other sites
rmaynard 16,873 #2 Posted October 8, 2011 What is the ID number on the 416-H. I'd like to look up the wiring diagram. :thumbs2: Share this post Link to post Share on other sites
Kelly 1,037 #3 Posted October 8, 2011 Well if it cranks, and you have power at the coil, I'd say check the points, clean with a point file or light sand paper. Share this post Link to post Share on other sites
TT-(Moderator) 1,169 #4 Posted October 8, 2011 An H would have an Onan, Kelly. (no points) If ALL wiring has been declared good, I suspect either a bad coil or trigger module ~ or both. Share this post Link to post Share on other sites
