Butch 194 #1 Posted October 6, 2011 These would allow me to go with the narrow tri-ribs. Will the 3/4" work? Is the mounting hole the same size of WH wheel? Thanks Share this post Link to post Share on other sites
shootinok 15 #2 Posted October 6, 2011 not sure what you're asking will fit as there's no picture. - however I'll assume you have some rims/tires in mind. The front axles are 3/4" but the difficult thing to get to fit is the length on the wheel hub. Wheel horses are mostly 3- 3/4" long. Most wheels are only 3" long. I had a heck of a time finding a replacement wheel for my C-121. The older Wheel Horses have a narrower rim (still with the long 3-3/4" hub) that works with the tri ribs. If you have the deep dish type rims, like I do, you can still get tri ribs but the 16X6.50-8's are pretty pricy. Share this post Link to post Share on other sites
Butch 194 #3 Posted October 6, 2011 Oops I forgot to add this: http://www.ebay.com/itm/130584057706?ssPag...984.m1423.l2649 Share this post Link to post Share on other sites
Irv 115 #4 Posted October 6, 2011 They won't fit-the bore length is too long. As Shootinok said, you need a 3 3/4 bore length-hard to find other than wh wheels. If they are a little less, you can use a washer or 2. Share this post Link to post Share on other sites
Butch 194 #5 Posted October 6, 2011 Thanks John and Irv. Share this post Link to post Share on other sites
Kelly 1,033 #6 Posted October 6, 2011 Rims from about 68 to around 75 will fit and are the narrow style about 3.5" wide, if you need a set send me a PM I have a few sets here. Share this post Link to post Share on other sites
EdG. 5 #7 Posted October 7, 2011 Maybe you could cut or machine some of the bore length off to make it fit. Share this post Link to post Share on other sites
kpinnc 14,669 #8 Posted October 7, 2011 Or you can use 3/4 spacers for narrower rim bores. They are about $1 each from Lowes or TSC: Good luck! Share this post Link to post Share on other sites
KC9KAS 4,744 #9 Posted October 7, 2011 Hard telling what else might be different than what is posted in the Ebay ad.....the color of the wheels is said to be orange, and I see yellow. Share this post Link to post Share on other sites
