fourwheels0 191 #1 Posted October 6, 2011 i just put my snowblower on and i think it has the wrong belt (it came with the blower). should the belt fit in the pully more? it just barely rubs the front housing. Share this post Link to post Share on other sites
C-Series14 15 #2 Posted October 6, 2011 Yep, looks too wide... Share this post Link to post Share on other sites
Butch 194 #3 Posted October 6, 2011 What's the Model # of your blower. People here will tell you what belt should be used plus you might be able to get it off the Toro site. Share this post Link to post Share on other sites
fourwheels0 191 #4 Posted October 6, 2011 the model is #6 6211 serial #522048 it is an older blower that had the short frame mount and i bolted up a long frame mount to it. everything fits fine and works like it should except the belt issue. because i changed the frame mount will i have a problem getting the right belt to work? like the length?. Share this post Link to post Share on other sites
fourwheels0 191 #5 Posted October 6, 2011 ok i think the correct belt should be #8231 i read the stens belt #248070 replaces the #8231. is this correct?. i should i have a 1/2 x 70inch belt correct?. Share this post Link to post Share on other sites
wallfish 18,437 #6 Posted October 6, 2011 The belt does fit tight between the pulley and the blower on all of them but it shouldn't touch. You can try moving the shaft back a little by loosening the bolts for the bearing, pull the shaft back if there is any play and re-tighten the bolts. I think mine only have about 1/8" clearance. If that doesn't work, you could change the pulley. The pulley on the blower should be 5 1/2" . The Toro belt # for the newer blowers is 9750 which is a 5/8 belt Share this post Link to post Share on other sites
Butch 194 #7 Posted October 6, 2011 I couldn't find anything. But I did find your blowers manual for sale on Ebay. Jdog from this site is selling it. Share this post Link to post Share on other sites
fourwheels0 191 #8 Posted October 6, 2011 The belt does fit tight between the pulley and the blower on all of them but it shouldn't touch. You can try moving the shaft back a little by loosening the bolts for the bearing, pull the shaft back if there is any play and re-tighten the bolts. I think mine only have about 1/8" clearance. If that doesn't work, you could change the pulley. The pulley on the blower should be 5 1/2" . The Toro belt # for the newer blowers is 9750 which is a 5/8 belt well sure enough i loosened the bolts on the bearing carrier and it slid back a touch. i now have plenty of clearance. thanks wallfish. Share this post Link to post Share on other sites
Kelly 1,033 #9 Posted October 6, 2011 I think the old blowers used a 1/2" belt the new use a 5/8" belt and if your running the new style belt on the old pulley it will not drop in the V as far as it should and that looks to be the case, but if you have it working your all set, just watch for belt wear. Share this post Link to post Share on other sites
fourwheels0 191 #10 Posted October 7, 2011 I think the old blowers used a 1/2" belt the new use a 5/8" belt and if your running the new style belt on the old pulley it will not drop in the V as far as it should and that looks to be the case, but if you have it working your all set, just watch for belt wear. yup i have the old style blower that uses the 1/2 inch belt. i will need to get a new belt though as this one definitely has some wear on it. i just wanted to get it hooked up and make sure everything works like it should and it does. a few minor things to do like smooth the inside of the shoot,new belt,grease everything real good and i'm ready for the snow. Share this post Link to post Share on other sites
