Electro12WH 50 #1 Posted October 2, 2011 The Breakerless Ignition from the late 60s - early 70s seems like a good idea. Why was it dropped? And, how did it differ from the M Series ignition? Share this post Link to post Share on other sites
Irv 115 #2 Posted October 2, 2011 I also think it was a good idea but don't know why they didn't continue to use it. I do know that a repacement coil and/or trigger switch is hard to come by and exspensive. It doesn't take much to ruin one or the other by just hooking up a wire wrong and/or crossing polarity. Share this post Link to post Share on other sites
shorts 182 #3 Posted October 4, 2011 As reliable as the early breakerless ignition is, I think that in a small engine application that points ignition is almost as reliable and therefore probably more cost effective. Share this post Link to post Share on other sites
Jim_M 179 #4 Posted October 4, 2011 Shorts hit the nail on the head. Point type ignition was just as reliable, maybe even more reliable, cheaper to manufacture and cheaper and easier to maintain, repair and replace. The Magnum ignition is a different type. It's much simpler, and more reliable. Share this post Link to post Share on other sites
Duff 206 #5 Posted October 8, 2011 Since we're on the subject, on the M-series engines with the breakerless ignition systems, how is spark advance compensated for, or is it simply not an issue between 0-3,600 rpm? Duff :banghead: Share this post Link to post Share on other sites
TT-(Moderator) 1,162 #6 Posted October 8, 2011 The timing is already at "full advance", Duff. The pre-ACR Kohlers had a two-piece camshaft with centrifugal timing advance. Once the ACR feature was introduced, retarding the timing to make starting easier wasn't needed. ~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~ The solid-state (transistorized / breakerless) ignition used the best technology available at the time ~ which is Neanderthalic compared to the newest systems. Three components were required to make it work (dedicated stator section / trigger (pick-up) / and transformer (coil) vs. an armature/coil with integral trigger and a magnet on the flywheel. Side note/reminder: The Kohler solid-state / breakerless ignition does not like water. Excess water inside the blower housing can/will fry the trigger unit. Share this post Link to post Share on other sites
