tbbahner 28 #1 Posted September 26, 2011 And no I don't mean anything kinky or physical by "jumping". Is there a way to jump start a starter/gen setup? I'm looking for a quick and dirty way to see if the engine will fire off before I do much else to it. I know I'll have to provide power to the coil but have never been around a S/G before. Hate to have to spend the time going through all the wiring issues. PO said it rolled off a trailer turning a corner and he never used it again. Thanks for any help. Tom B Share this post Link to post Share on other sites
rmaynard 16,992 #2 Posted September 26, 2011 If you are trying to work around the start switch, you just need to connect (-) to ground, and (+) to the "A" terminal of the S/G. As you said, you need to provide (+) 12v to the coil. Share this post Link to post Share on other sites
TT-(Moderator) 1,169 #3 Posted September 26, 2011 I like to use a switch-controlled booster pack, but you can use jumper/booster cables if you don't allow them arc at the armature ("A") stud of the starter motor. (can damage the threads on the stud) A piece of strap steel (or similar) bolted to the "A" post will give you a bigger & safer target for the cable clamp. :thumbs2: Share this post Link to post Share on other sites
tbbahner 28 #4 Posted September 27, 2011 Thanks guys. Good suggestion on the A post Tom B Share this post Link to post Share on other sites
