allredman 0 #1 Posted September 24, 2011 would someone tell me how to adjust cluch? if i just get my foot close to the peddle it slips. it has no slak peddle. i have a new belt on it. double checked if it is the right one for it.the tractor is a c 101 high/low. thanks so much. jim Share this post Link to post Share on other sites
rmaynard 16,875 #2 Posted September 24, 2011 There is a trunnion at the end of the clutch rod that can be adjusted. As long as you are using the correct belt (P.N. 7473), correct return spring, and have the belt cover installed properly, you should be able to properly adjust it. Share this post Link to post Share on other sites
MikesRJ 558 #3 Posted September 24, 2011 Section 5, starting on page 5-2 for "C" model: http://www.mywheelhorse.com/graphics/file/...al_810063Rl.pdf Share this post Link to post Share on other sites
