Will G 3 #1 Posted September 23, 2011 Can someone provide me insight on how to remove the PTO assembly and drive pulley on a 1979 C-111? Share this post Link to post Share on other sites
rmaynard 16,589 #2 Posted September 23, 2011 Once the PTO housing rod (the curved rod) and the PTO brake has been removed, the PTO bell should slide off. Remove the 4 screws that hold the retainers in place, remove the retainers, and slide the bearing race off the crankshaft. Remove the clutch plate. There are 2 setscrews in the pulley. Loosen or remove them, and using an appropriate gear puller, remove the drive pulley. Though the C-111 is not specifically covered, the PTO removal procedure is in the B,C,D service manual. http://www.mywheelhorse.com/graphics/file/...al_810063Rl.pdf Share this post Link to post Share on other sites
