Duff 207 #1 Posted June 17, 2008 Hi, folks! Will the front wheels from a 520H fit my 312-8 if I don't have the mower deck on it (in other words, for pulling)? Thanks much! Deerman :whistle: Share this post Link to post Share on other sites
kj4kicks 154 #2 Posted June 17, 2008 If you change the wheel bearings, yes. The 520 uses 1" spindles, and the 312 uses 3/4". You can swap the bearings form the wheels, and not have to buy new ones. Share this post Link to post Share on other sites
Duff 207 #3 Posted June 17, 2008 Thanks, Eldon! Deereman :whistle: Share this post Link to post Share on other sites
Curmudgeon 28 #4 Posted June 17, 2008 I can't swear it, but are the spindles the same length? And what about the difference between the bearing types? Straight versus tapered. I'm not saying they won't swap, but there is more difference than just spindle diameter. Share this post Link to post Share on other sites
Kelly 1,038 #5 Posted June 18, 2008 I think the older 520's had 3/4" spindle's???? the newer one's with the taper bearings 1" I'm pretty sure have a larger bore where the bearing goes in the rim, so you will not be able to put your smaller 3/4" bearings in them. I have some D spindles that are 3/4" and have sleaves on them to use 1" bearings, just a thought. My two cent's Share this post Link to post Share on other sites
Rollerman 291 #6 Posted June 18, 2008 I can't swear it, but are the spindles the same length? Dale is right here...520's have a 1" spindle & were infact longer than the standard type 3/4" spindles. This is atleast true for the two I have had....earlier models may be differant? Share this post Link to post Share on other sites
Duff 207 #7 Posted June 18, 2008 Wow! Thanks as always for the excellent info, and advice - you saved me an embarassing and unnecessary purchase from Fleabay! So..... if I want to go to a taller set of front wheels on my 312-8, what's my best route? Thanks, guys! Deereman :WRS: Share this post Link to post Share on other sites
Curmudgeon 28 #8 Posted June 18, 2008 Did your 312 come with 6" wheels? If so, there are any number of tractors which used an 8" wheel that will most likely fit. In fact, just about anything other than the wheels from a 520 or D series, that are the same width. Some of the earlier ones had narrower tires and wheels. Correct me if I'm wrong boys, and I'm sure you will!!!!!!! LOL Share this post Link to post Share on other sites
TT-(Moderator) 1,173 #9 Posted June 18, 2008 .....and don't forget the clearance issue with the left front wheel and the 37" two blade deck. That is what prompted the use of the 6" front rims in the first place. Share this post Link to post Share on other sites
Duff 207 #10 Posted June 18, 2008 .....and don't forget the clearance issue with the left front wheel and the 37" two blade deck. That is what prompted the use of the 6" front rims in the first place. Hi, guys, and thanks! Yeah, I had caught the warning about the clearance issue with the 37" SD deck on other threads here, so I am looking for using the larger tires only when I want to use the tractor for pulling or with the grader blade. Of course, if that 312-8 in Laconia, NH (less than an hour away from me) TT posted the link to is still available, I may have a tractor for each purpose. Now wouldn't that be just too bad? Deereman :whistle: Share this post Link to post Share on other sites
Duff 207 #11 Posted June 18, 2008 OK, here we go again, boys. Please bear with me....... Will a set of 23x9.50x12's off a 520H fit on the rear of my 312-8 or will the fender clearance, etc. be too close (ignoring the mower deck for now....)? Thanks for your patience! Deereman :whistle: Share this post Link to post Share on other sites
TT-(Moderator) 1,173 #12 Posted June 18, 2008 The ones in ME that are listed on ebay? Yes, they will fit fine, and if the fronts you were asking about are THESE, they will fit too. Note: The spindles for the 6" front wheels are a little longer, but I changed my 416H over to 8" fronts and kept the original longer spindles. It doesn't seem to affect anything either way. :whistle: Share this post Link to post Share on other sites
DMESS 24 #13 Posted June 18, 2008 88'-89' 520-H will work as these did not yet have the 1" spindles. 520-HC and 1990 and later 520 have the 1". And now I see TT covered that with the ebay link! Share this post Link to post Share on other sites
Duff 207 #14 Posted June 19, 2008 The ones in ME that are listed on ebay? Yes, they will fit fine TT, you are one amazin' dude! Yup, the rear ones over in Freedom, ME on fleabay. My only reservation now is with the seller - he had them listed before and eBay kicked him off the auction (something called an SHMO notice, but no real explanation what that is or means) about two hours before I would have presumably won the bid. But the wheels/tires look good and worst case, Freedom isn't that far away from me in case I had to go over and, shall we say, settle things man to man. The fronts I'm looking at are actually from a 417A also on fleabay. I'd show the link but I don't know how you go about doing that in this forum (yet). The earlier posts on this thread about the 520H fronts got me looking for something closer to my own machine. As always, you are the greatest! Deereman :WRS: Share this post Link to post Share on other sites
