last12know 0 #1 Posted September 20, 2011 got a mid mount grader blade.. thanks again joe. anyhow while there joe said i just needed a tach matic and i was good. thought i had one but it appears i have two solid plates holding my deck.. i haven't tried to swap yet as it's late but is the ma-1 really needed or is it just easier to swap stuff with. i don't mind a little extra work but the toro accessorie page i was on said that the mid mount grader requred the speed hitch. next question.. lots of speed hitches listed and they all seem to look similar but no part number just the tractor they came off on ebay.. are they all the same? thanks for your patience. brian Share this post Link to post Share on other sites
Kelly 1,036 #2 Posted September 20, 2011 Your plates you have will work, but the newer style hitch is easier, but will not work with your deck, I'm pretty sure any of them will bolt on to your machine, the early style don't have the lock pin built in to them, you close the hitch latches , then put a cotter key in a hole to hold the latches closed. Share this post Link to post Share on other sites
