spark949
PTO cones
spark949
The inner shaft on my PTO cone is very sloppy and make alot of noise when engaged. It's on my 520h (new to me). I'm wondering what cones on other models might fit. For instance I'm looking at these.
http://www.wheelhorseforum.com/index.php?showtopic=29798
thanks, Fred
rmaynard
The inner shaft is your crankshaft. It is covered with a sleeve or more properly stated, bearing race. The inner needle bearing (Toro P.N. 106769) rides on that. The inner bearings go bad. You might want to try replacing that and the outer bearing as well. Between the two of them, you will pay about $20.00 plus shipping.
Be careful buying used as they may also need to be rebuilt.
The two PTO cones in the other thread were taken from a couple of B-80's if I am not mistaken. They should be the same as your 520-H.
thehorse
Do you have a website for the mentioned bearings please and thank you?
Duff
http://www.jackssmallengines.com/searchdb2.cfm
The price has gone up a bit (?) since this thread was started back in 2011, but the parts are still available.
6658 is the race - $43.44
106769 is the large needle bearing - $22.12
Duff :thumbs:
TT
Here's some great info courtesy of Bob Maynard & the gang:
