jimbo7921 9 #1 Posted September 10, 2011 Can anyone tell me the length of the belt that runs the 3 deck blades. The parts list tells the length of the drive belt to the tractor, but not the other. My decks serial number is 78390. thx jim Share this post Link to post Share on other sites
TT-(Moderator) 1,162 #2 Posted September 10, 2011 If you have the Toro/WH part number, you can look it up on this list: http://outdoorpowerinfo.com/belts/toro_belts.asp This site will help if you're looking for non-OEM belts: http://www.gates.com/part_interchange/inde...ocation_id=3286 Share this post Link to post Share on other sites
jimbo7921 9 #4 Posted September 10, 2011 Second question, when i lift my deck the only thing i can get off the ground are the front wheels of the deck, the rears still run on the ground. I have installed all new parts for the attach a matic and tightened the rear threaded rod connected to the adjustment bar on the rear wheels (i seemed to get a little more lift when i left it loose) any ideas anyone? There has to be an adjustment I'm missing somewhere, the goal is to at least get the rear wheels off the ground. thx jim Share this post Link to post Share on other sites
stevebo-(Moderator) 8,557 #5 Posted September 11, 2011 jimbo- That is as far as it will lift. They are big and heavy but cut great !! Share this post Link to post Share on other sites
cheesegrader 433 #6 Posted September 12, 2011 My 60" deck uses a 131" x 5/8' spindle belt (Toro 112449) and a 102" x 1/2" drive belt, (Toro 1130720 but the model number is different ---C560sc01 Share this post Link to post Share on other sites
jimbo7921 9 #7 Posted September 12, 2011 thx cheesegrader, I found the length on terrys list and ordered two Kevlar wrapped aftermarket belts for $60 instead of the toro belts which would have run about $160. Share this post Link to post Share on other sites
SAM58 30 #8 Posted September 12, 2011 Just go to Tractor Supply and buy a 1/2" x 100" belt for around $15.00 Series A-100 1/2" x 100" Share this post Link to post Share on other sites
jimbo7921 9 #9 Posted September 12, 2011 Well, the Tsc store's here in Canada don't sell parts like that here, they actually are more like the farmers Home Depot. For me to order parts here from Toro costs about 5 to 15$ more than Parts Tree, and there isn't a whole lot of used either. Gotta save a couple bucks here or there. Share this post Link to post Share on other sites
