mr.pipes 4 #1 Posted September 5, 2011 Does anyone have a link to a parts breakdown of the gearbox for a 44" two-stage blower? Blower model # 79361 Toro part # 116938 It is a peerless gearbox if I recall. I located it previously but cannot seem to find it at the moment. :thumbs2: Share this post Link to post Share on other sites
MikesRJ 558 #2 Posted September 6, 2011 1) Go here: https://homeownersolutions.toro.com/portal/...product_center/ 2) Enter 79361 and click the SEARCH button 3) Select the year (by serial number) 4) Click the LOOK UP PARTS button. What you are looking for is part of the "Gear Case and Belt Assembly" print Share this post Link to post Share on other sites
mr.pipes 4 #3 Posted September 6, 2011 Thanks Mike but I was looking for the breakdown of the gearbox itself. I think I found it but will have to check mine for model and serial #'s when I have a chance. This is what I found but not 100% if this is the right one yet. http://www.odref.com/peerless/differential...00-1000-014.pdf Share this post Link to post Share on other sites
MikesRJ 558 #4 Posted September 6, 2011 Sorry, can;t help you with the OEM part info. Share this post Link to post Share on other sites
HorseFixer 2,013 #5 Posted September 6, 2011 think I found it but will have to check mine for model and serial #'s when I have a chance. This is what I found but not 100% if this is the right one yet. http://www.odref.com/peerless/differential...00-1000-014.pdf Thanks Pipes! Will ck mine out also.... In looking at the page I notice they have 4 part #s for input shafts that look to be different lengths The reason I asked was mu cheap stamped pully on mine exploded last year and I put a compression pully on there. The only problem is the shaft could be 3/4" longer to give a little more MEAT for the pully to bite down on. But how come they dont list the lengths on the others or the diferences on the 66, 66A, 66C? Was gonna have my Machinest make to right length If I could get a spare. Anyways thanks for the link and keep me posted Ill do the same 4 U. Cheers ~Duke :thumbs: Share this post Link to post Share on other sites
gwest_ca-(File Mod) 11,474 #6 Posted September 6, 2011 Toro 116938 Peerless 1000-014 gearbox Garry Share this post Link to post Share on other sites
