P3x 57 #1 Posted September 4, 2011 Looking for a Vac. Bagger to fit a 48" Deck on a 520H. The Interchange doc shows two different PN Vac Baggers to fit different Model Tractors (79301, 79203). The 79203 is applicable to the 265H Model Tractor with a 42/48" Deck. I compared some of the Impeller component PNs and many seem the same. Will a 79203 mount on a 48" Deck mounted on a 520H. What is the major difference between the two? Thank you, p3x Share this post Link to post Share on other sites
zieg72 209 #2 Posted September 4, 2011 I think the only difference you are going to find is the part numbers of the pulley and how it mounts to the 48" 265 tractor deck versus the one on your 520H that will drive the attachment impeller. Share this post Link to post Share on other sites
P3x 57 #3 Posted September 4, 2011 Thanks for th info Zieg72. I did not think there would be major differences in the different model component parts. But wanted to check before considering a different model specified. p3x Share this post Link to post Share on other sites
bk-scouter 93 #4 Posted September 5, 2011 I believe that the blower unit is the same that is used on the 5xi series too. You would need to check the illustrated parts lists to see how much more can be used from that tractor such as the bages, bag cover, chute and mower pulleys. The 240 series (244-5, 244-h, 246-h) all have the same components as the 3, 4 and 500 series with the exception of the deck pulleys and cover, and bag support rod. -BK Share this post Link to post Share on other sites
marc 0 #5 Posted May 11, 2017 On 9/5/2011 at 9:53 AM, bk-scouter said: I believe that the blower unit is the same that is used on the 5xi series too. You would need to check the illustrated parts lists to see how much more can be used from that tractor such as the bages, bag cover, chute and mower pulleys. The 240 series (244-5, 244-h, 246-h) all have the same components as the 3, 4 and 500 series with the exception of the deck pulleys and cover, and bag support rod. -BK where would i find info as to what baggers would fit a 244-5 with a 38" deck Share this post Link to post Share on other sites
Snowmobileaddict 403 #6 Posted May 11, 2017 1 hour ago, marc said: where would i find info as to what baggers would fit a 244-5 with a 38" deck The link in this post is for the master attachment interchange chart. Just look up your model and read the chart to see what fits it. -Andy Toro Wheel Horse Attachment Interchange 1955-00.pdf 1 Share this post Link to post Share on other sites
LeeJ 0 #7 Posted July 18, 2019 (edited) Will the 79301 for the GT model fit the same as the 79203 for the 266H 48" deck (78261)? Seem slike most all are very close except mounting hardware and belt cover Edited July 18, 2019 by LeeJ More info Share this post Link to post Share on other sites
gwest_ca-(File Mod) 11,757 #8 Posted July 18, 2019 Compare the parts lists https://www.wheelhorseforum.com/search/?&q="79203"&type=downloads_file&search_and_or=or&sortby=relevancy https://www.wheelhorseforum.com/search/?&q="79301"&type=downloads_file&search_and_or=or&sortby=relevancy Garry 1 Share this post Link to post Share on other sites
