CRE1992 135 #1 Posted September 3, 2011 Im trying to help a friend that has a 520H, it blows the 30 amp and the 20 amp fuses. The started will not turn over when the key is turned to the start position, but if you jump the solenoid it starts... I believe there maybe a dead short somewhere, any ideas? If so where should I look? Thanks Charles Share this post Link to post Share on other sites
canam1991 2 #2 Posted September 3, 2011 had the same problem in the harness plug under battery between the motor on mine the red wire was green under the plastic Share this post Link to post Share on other sites
rmaynard 16,349 #3 Posted September 4, 2011 You might want to start with a wiring diagram to help you determine where to look. What year is the tractor? Share this post Link to post Share on other sites
CRE1992 135 #4 Posted September 4, 2011 it's a 1993. Share this post Link to post Share on other sites
SAM58 30 #5 Posted September 7, 2011 I would start by cleaning the connections between sections of the wiring. The 9 pin connection would be where I would start, (weak link in the chain) then the fuse box, the clips that hold the fuses will turn green and get weak giving a bad connection. If the 30 amp fuse had a bad connection it will not turn over. Check to make sure the ground is still grounding... Possibly the connection on the key switch as well, may not be as bad as you think. Electronics cleaner Electrical grease Possibly new fuse box & connectors. (parts are available) Wheel Horse Parts Share this post Link to post Share on other sites
boovuc 1,090 #6 Posted September 8, 2011 If the 9 pin plugs "look" OK, go over the whole wire harness looking for contact with metal. If that harness was removed or rerouted from the clips, vibration could have worn the insulation off causing a direct short to ground. Had that happen on my 416. Next would be looking at the fuse holder. There are enough stories of these melting away on this site. BooVuc Mill Hall, PA Share this post Link to post Share on other sites
