Wheel Horse Kid 105 #1 Posted September 3, 2011 I am trying to get my 48" side discharge mower deck off of my 1986 Wheel Horse 312-8. It is a attach a matic system. This is what I have done thus far: I have lowered the mower deck and put the height of the deck to the lowest setting. I have turned the wheels to the left. This is my problem: The attach a matic knob of the front of the tractor will not move either to the right or the left. I have lubricated it with WD-40 to try to loosen it up, but it will still not move at all. Is there something that I doing wrong or have not done right? I would appreciate any help. Thanks! Share this post Link to post Share on other sites
Butch 194 #2 Posted September 3, 2011 Try hitting the left side (knob/rod) with a hammer. You gotta push it in for the mule to release. Share this post Link to post Share on other sites
C-Series14 15 #3 Posted September 3, 2011 The knob won't turn... Take the deck off and slide it forward to remove tension on the mule drive system. Remove the belt from the deck THEN remove the mule drive so you can get to the threaded rod to inspect it and see what is wrong. Share this post Link to post Share on other sites
tarcoleo 120 #4 Posted September 3, 2011 Not sure I read you clearly- the mule drive I'm sure you know needs to be loosened by turning the adjustment knob clock-wise. This should not be difficult any which way you can. It is not necessary to remove the MD. After that, get the belt out of the way, and undo the mid-mount latch. Pull the deck out. If the mule drive adjustment is frozen, well I can't imagine why that would be. I must be confused. Tom in RI :thumbs2: Share this post Link to post Share on other sites
Wheel Horse Kid 105 #5 Posted September 3, 2011 Thanks for all the help! I finally did get the deck off the tractor. Share this post Link to post Share on other sites
