MaineDad 87 #1 Posted September 2, 2011 Guys: I am about to reassemble the K301 since I had new guides installed. I will do a write up on that later. The question I have is what ring goes on top on the piston? The thicker one or the thinner one? These rings have about one hour run time on them and I know one is chrome, but I cannot tell which one is the chrome one anymore. I tried to wipe away the carbon to see, but was not sure. One is definitely thicker than the other one. Share this post Link to post Share on other sites
TT-(Moderator) 1,169 #2 Posted September 3, 2011 There should only be one way that they can be installed so the side clearance doesn't exceed the spec - which I believe is .006" max. Share this post Link to post Share on other sites
rmaynard 16,699 #3 Posted September 3, 2011 You might also want to check the drawing in this post as well. http://www.wheelhorseforum.com/index.php?...topic=30971&hl= Share this post Link to post Share on other sites
