anixon92 0 #1 Posted September 2, 2011 Have a old L156 lawn ranger i just pick up and was wordering if there is a snowplow made for it. If so what kind would i be looking for. I only have a small driveway and figured if they made a plow, i would try to pick one up for it. So if they do i'm looking to purchase a blade for it. I'm in new jersey. thanks al Share this post Link to post Share on other sites
jdog_kustoms 82 #2 Posted September 2, 2011 they have snow blades and blowers for them i have both for my sons lawn ranger i can get you the model numbers of them Share this post Link to post Share on other sites
CasualObserver 3,411 #3 Posted September 2, 2011 There's a correct blade for sale in this thread. http://www.wheelhorseforum.com/index.php?...ndpost&p=253635 Of course, it's in the Indiana, and you're in New Jersey, but at least you can see what it looks like. Share this post Link to post Share on other sites
Lane Ranger 11,694 #4 Posted September 2, 2011 Here are a couple good photos of my 1967 Lawn Ranger with the 32 inch snowplow/dozer blade attached: Dozer Lift Pieces: Share this post Link to post Share on other sites
anixon92 0 #5 Posted September 2, 2011 boy i wish my looked that great. thanks Share this post Link to post Share on other sites
Lane Ranger 11,694 #6 Posted September 3, 2011 anixon92: The first two photos with the 1967 Lawn Ranger showing the plow (plow has been repainted) -also shows the paint and finish. A real closeup will show some scratches and dings but this tractor actually has the original paint and decals. :thumbs2: Share this post Link to post Share on other sites
pfrederi 19,376 #7 Posted September 3, 2011 Blade is Model BDR-385 They show up occasionally but are usually missing the side mounting plates (the gray steel plate in the picture). I had to make my own but then the blade only cost me $11 so I couldn't complain about their absence. She will push a lot of snow!! Share this post Link to post Share on other sites
anixon92 0 #8 Posted September 3, 2011 ok thanks for heads up on blade . will have to keep watching for a plow. another question i just mounted mower deck and the front of deck is lower then the back end of it. how to you go about adjusting height. i try to find a manual for deck and tractor but no luck. thanks al Share this post Link to post Share on other sites
pfrederi 19,376 #9 Posted September 3, 2011 The front of a deck should be slightly lower than the rear. 1/8 to 1/4" lower. (reach underneath and measure the front and back end of the blade. There is no adjustment on the deck for leveling. If you deck is way down in the front I would suspect excessive wear in the "Link Mower Hanger #6234) or in the frame holes they mount in. My father used my L107 for many years mowing a rough lot. The spacers that fitted in the hangers had worn out and the hanger holes had wallowed out. First try new spacers. (you can get them at a hardware store). If that doesn't work and you still have slop like I did, I had the holes welded shut then re drilled them to size. The holes in the frame rails also wore. You can drill them over size and use a shoulder bolt or some spacers. I will try to remember to take some measurements tomorrow. Share this post Link to post Share on other sites
305 380 #10 Posted October 23, 2011 hello! bring this older thread back up to get some more info looks like i have made a deal to get a BDR385 plow for my Lawn Ranger next month, but i may or may not be getting the frame mounting brackets. either way , they look simple to make and i'm bored this afternoon so i thought i would get a start. i can extrapolate some dimensions by the pictures and comparing to my tractor. the two 3/8" bolt holes in the picture are 4" apart on my Lawn ranger what i would like to get help on is the exact location on that large pivot hole and the diameter. any help? thanks! i borrowed this picture from above Share this post Link to post Share on other sites
TT-(Moderator) 1,169 #11 Posted October 23, 2011 The mounting plates are exactly like the side plates for the 1964-1967 MA-1 speed hitch, with the exception of the slots being 3/4" holes. Full credit for this print goes to RS member "Jim_M" (hope he doesn't mind ): Share this post Link to post Share on other sites
305 380 #12 Posted October 23, 2011 that is great! thank you! Share this post Link to post Share on other sites
littleredrider 409 #13 Posted October 23, 2011 I have a plow for the ranger, if you need any measurements I can get some.... I was really amazed how well they push snow for such a small lite tractor.... Share this post Link to post Share on other sites
