oldnugly 2 #1 Posted September 2, 2011 I have two 1974 "C" series 8 spds. The C-160 uses a 1/4"dia latch type pin thru the PTO. The C-100 and my 1972 Charger10 have 'improvised' 5/32" dia. pins and it's a tight fit. The C-160 has a lower serial number than the C-100. Is the pin size is related to the HP?? There is a pin on beeBay right now but it's 1/4" dia . Does anybody have a couple 5/32 pins or know where to get them? Share this post Link to post Share on other sites
SousaKerry 503 #2 Posted September 2, 2011 I'm no expert but I believe the smaller holed ones used a large hair/hitch pin as for the larger 1/4 inch one save the shipping money they are available at any farm store for a couple of bucks. Share this post Link to post Share on other sites
truckin88 104 #3 Posted September 2, 2011 Lowes has them as well Share this post Link to post Share on other sites
BOWTIE 226 #4 Posted September 3, 2011 HELLO, I TRIED ONE FROM HOME DEPOT AND THE LARGE END WOULD RUB THE PTO DRUM. TRY TO BUY THE CORRECT ONE OR USE A 1/4" BOLT WITH A STOP NUT. I USED A LONGER BOLT AND CUT IT OFF SO IT WOULD HAVE SMOOTH SHANK WHERE GOES THRU THE BUTTON. IT'S BETTER THEN HAVING IT RUB THE DRUM. HOW OFTEN DO YOU REMOVE THE PIN ANYWAYS. JUST MY TWO CENTS WORTH. BOWTIE IN COLUMBUS Share this post Link to post Share on other sites
truckin88 104 #5 Posted September 3, 2011 lowes clears, I just put one in last night Share this post Link to post Share on other sites
WH854 45 #6 Posted September 3, 2011 HELLO, I TRIED ONE FROM HOME DEPOT AND THE LARGE END WOULD RUB THE PTO DRUM. TRY TO BUY THE CORRECT ONE OR USE A 1/4" BOLT WITH A STOP NUT. I USED A LONGER BOLT AND CUT IT OFF SO IT WOULD HAVE SMOOTH SHANK WHERE GOES THRU THE BUTTON. IT'S BETTER THEN HAVING IT RUB THE DRUM. HOW OFTEN DO YOU REMOVE THE PIN ANYWAYS. JUST MY TWO CENTS WORTH. BOWTIE IN COLUMBUS I agree I have tried those after market pins, they just look pretty, they are made the wrong way. Invest in a good Wheel Horse P/N 111314 cost about $12.00 frim Toro, But your headache will be over Chas Share this post Link to post Share on other sites
bigd 0 #7 Posted September 3, 2011 i have pins from tractor supply in all mine no problems Share this post Link to post Share on other sites
