Stigian 1,234 #1 Posted June 14, 2008 Howdo all, first of all sorry for the lack of build posts from me Life has never been so busy, so finding WH time (apart from grass cutting) has been hard. In other news i have been given the from my landlord to extend my workshack The bad news is lots of digging is needed to put a decent base down. My snowplow/blade will be handy for pushing earth about, but i need something to loosen it all first. HHmmm i feel a build coming on Chapter 1 - Heavy metal and a big spring. First job was to get the clevis hitch off the trans from whats left of my 1971 Raider 10. Not a fun job due to many years of rust. In the end i had to cut the pin both sides Anyway, after lots of swearing/smoking/drinking coffee the clevis hitch moved to its new home After a bit of ing about what to build the harrow out of, i noticed that the two bolts on the clevis hitch were almost in the right place for bolting on a tow bar Ta-Daa a Mercedes C class tow bar How to file and smile as demonstrated by Garry This chunk of metal is what the tow ball would bolt onto, but with quite a bit of file work to make the holes closer together it bolts onto the clevis hitch It was at this point that we first noticed the big bit of box section was longer one side. Oh well, time to buy some more cutting disc's. While attempting to set himself on fire with hot sparks, Garry also managed to make a start on cutting the tine/digging in the earth bits Thankfully Garry remained unburnt and cut all 9 of the tine 's, as shown on the WH display table Time for some serious metal cutting First off was the very solid mounting plate's, closely followed by a trim to a couple of mounting brackets. Thats looking better with all the junk removed, and a bit of trimming down one side to get both sides the same length. Oh, you may of noticed the bar is mounted so the ends hang down now, and not point up. Pause to catch my breath :D Share this post Link to post Share on other sites
Stigian 1,234 #2 Posted June 14, 2008 Breath back and smoke rolled, now where was i? Oh yes, tine attachment time A bit of ing was called for as the main harrow bar/ bit of box section wasnt straight, but at least it was bent evenly The center tine was welded on first after making sure it was in the right place and more importantly square. With a straight edge clamped on the end of that tine, it was easy to work out the correct height for the rest Never being someone to miss a chance of taking a daft photo Death Race 2000 anyone? I think it looks better as a harrow As always safety was on my mind so i though some kind of trip spring would be a good idea, just in case the tines catch on anything big and solid buried underground. Its only mocked up in this photo, but you get the idea. The three bolt holes on the green bit will mean i can change the angle of the tines as well as the shock giving me adjustable spring tension Thats all for now, stay tuned for more of the same :D Share this post Link to post Share on other sites
Rollerman 290 #3 Posted June 14, 2008 Cheers Ian & thanks for shareing your harrow We've been waiting for the next Ian Buildup Fix.... Hope it works good for you as a harrow...but you may need to do some pulley/motor mods for the death race. Do I see a dual hyd lift dozer,harrow,dualy tire, stacked tractor in the works now? :whistle: Share this post Link to post Share on other sites
Jim_M 179 #4 Posted June 14, 2008 Nice job Ian. You're like the Dr. Frankenstien of the Wheel Horse world, scrounging parts from dead equipment and combining it into a useable thing. Share this post Link to post Share on other sites
kj4kicks 154 #5 Posted June 14, 2008 Another great Fab job Ian & Garry ! Lookes like it will tear up some dirt. Share this post Link to post Share on other sites
Nick 13 #6 Posted June 14, 2008 The harrow thingy looks great and should do some damage on the dirt. Maybe ya should put a slip scoop on the build list to move dirt and building material. Might also want to make the harrow tines flip up straight for the death race. Some of Carradines finest work. :whistle: Share this post Link to post Share on other sites
WheelHorse_of_course 100 #7 Posted June 14, 2008 Ian, well done. Are you going to use this to open of some water flow out of your nasty swampy areas? Nah, that would be no fun :WRS: Share this post Link to post Share on other sites
KyBlue 655 #8 Posted June 14, 2008 Nice Construction Work!! Looks fantastic Cant wait to see it finished and in action Share this post Link to post Share on other sites
CasualObserver 3,411 #9 Posted June 14, 2008 Awesome and well narrated... as always!! :whistle: Share this post Link to post Share on other sites
TT-(Moderator) 1,162 #10 Posted June 14, 2008 Ian, that's a looking ripper you fabbed up! Kinda reminds me of ones used on dozers. The shock damper is a great idea, and it will be nice to be able to increase or decrease the angle of the "teeth" by just changing the pin location. :D Share this post Link to post Share on other sites
kpinnc 15,720 #11 Posted June 14, 2008 Most impressive Ian! Great idea with the trip feature as well! Keep us posted! Kevin Share this post Link to post Share on other sites
Teddy da Bear 11 #12 Posted June 14, 2008 Interesting...and good concept. But if I remember the photo correctly....you used square tubing for the tines and just angle-cut the ends of each tine? I think it would be more effective of "cutting" into the soil if you had more of a knife edge on the leading edge of those tines. Thankfully Garry remained unburnt and cut all 9 of the tine whtractor/thingy.gif 's, as shown on the WH display table biggrin.gif I've got one of those tables too! Doubles as a saw horse, work bench and tool holder. :whistle: Share this post Link to post Share on other sites
Mith 2 #13 Posted June 15, 2008 Looking good Ian. Isnt big steel so much fun Looks like 1/4" wall box on the frame? BTW, that grinder photo made me cringe, I've got a bit of a grinder safety complex after the whole grinder finger slice thing.... (get a handle for it ) Share this post Link to post Share on other sites
Stigian 1,234 #14 Posted June 16, 2008 Wow... Cheers for all the great comments guys It makes all the hard work worth while We've been waiting for the next Ian Buildup Fix.... Glad to help you all with a build fix I have missed having the time to build something, you cant beat being down the shack welding and grinding Do I see a dual hyd lift dozer,harrow,dualy tire, stacked tractor in the works now? You never know Stephen Oh anyone know if the steel cable that lifts the clevis hitch on the Raider will fit my 312? Nice job Ian. You're like the Dr. Frankenstien of the Wheel Horse world, scrounging parts from dead equipment and combining it into a useable thing. Cheers Jim M, that really make me smile I like to use what i have around me and make it work. Do you guys ever catch yourselves looking in skips (are they called small dumpsters in the US?) (oh, not idea why we call them skips by the way) in other people yards/gardens for usable junk? My Wife and i found are selves doing just that while sitting in the back of a vintage Roll Royce on the way back from getting married Another great Fab job Ian & Garry ! Looks like it will tear up some dirt. Cheers Eldon, i hope it will tear up the dirt my back isnt upto loads of digging these days Garry is one of those great guys thats alway willing to head over and help out of he isnt working. Building things would take so much longer without Garry's help, so cheers old chap for all your help and the mad moments you bring The harrow thingy looks great and should do some damage on the dirt. Maybe ya should put a slip scoop on the build list to move dirt and building material. Cheers Nick. Not quite sure what you mean by a Slip Scoop ,but i am planning on building a blade type that will attach onto the harrow tines so i can drag dirt about and not just loosen it. well done. Are you going to use this to open of some water flow out of your nasty swampy areas? No nasty swampy area about at the moment, in fact my garden is slowly starting to turn into a dust bowl. So maybe i need to dig something for getting water into the garden TT That dozer in the photo looks like it would be great fun to have a "play" with Im not sure my Landlord would be too happy if i cut a 8 lane highway through one of his fields though Most impressive Ian! Great idea with the trip feature as well! Cheers Kevin, as for the trip feature... well i had to build in a bike part somewhere Interesting...and good concept. But if I remember the photo correctly....you used square tubing for the tines and just angle-cut the ends of each tine? I think it would be more effective of "cutting" into the soil if you had more of a knife edge on the leading edge of those tines. You did remember the photo correctly Mike Putting knife edge cutting 's on the tines is one of the jobs on the list to do. Also by "blanking" off the bottom of the tines, means i can fill the tines with something hard and heavy. A bit of extra weight is always handy, and as the tines are quite thin walled a bit of extra strength in them cant be a bad idea Looking good Ian. Isnt big steel so much fun Looks like 1/4" wall box on the frame? BTW, that grinder photo made me cringe, I've got a bit of a grinder safety complex after the whole grinder finger slice thing.... (get a handle for it Cheers Jim Yeah this "heavy metal" is quite fun to play with... I must add a plasma cutter to my wish list though Dont worry Jim, ive no plans to cut any of my fingers off with the grinder I do have the handles for my grinders somewhere, but i find i have much more control over the grinder without one. Also more comfortable to use. I should wear gloves when grinding as well, but i never do. Its like driving with boxing gloves on, you cant "feel" whats happening. Catch you all later with an update, the workshack is calling :D Share this post Link to post Share on other sites
Stigian 1,234 #15 Posted June 16, 2008 HHmmmm looking at my last post ive no got the "quote" button lark worked out yet. Oh well im sure i will get loads more practice Chapter 2 - That big spring and some lighter metal. Its been one of those days where despite the best layed plans, things didnt go quite according to plan so its a bit of a small update im afraid Continuing where i left off yesterday, i got the mounts welded on for the trip shock For those of you that are wondering what its from, it came off of a kawasaki Z200. For someone who is more used to welding panels made from computer case's, welding this thick steel is a bit of a challenge even with the MIG turned right up! Got there in the end though Angled back Angled forward Oh, i added some extra holes for more adjustment. And now onto the slightly lighter metal As recommended by Mike the cutting tines would work better with a knife edges on the leading edge of the tine. Ta-Daa 9 cutting pointy 's Here they are partly welded in place. I must remember to be careful not to kick them as i walk past A view from the top And thats about it for this update, i didnt get as much done as i wanted too today,but there's always tomorrow :D Share this post Link to post Share on other sites
Nick 13 #16 Posted June 16, 2008 The cutting pointy thingys give it a look. Slip scoop buckets have come to be more often called Johnny buckets and Im sure you have another term for them over the pond. This is what I made with scrap metal. It can lift 100 to 200 pounds without to much pain in the lift arm. Share this post Link to post Share on other sites
Stigian 1,234 #17 Posted June 17, 2008 Evening all Cheers for posting your pic's Nick Nice work by the way A slip scoop/johnny bucket would be a very handy thing to have, just added it to the "must build one day" list Today has been a fun and testing day, well the testing has been fun Chapter 3 - A bit of welding, a bit of fun, and some bent bits. Start the day the welding way Im sure a doctor would recommend a nice healthy no fat breakfast and a jog around the park, but i prefer welding Dont you just love it when a plan, (sorry) weld come together Im not sure if you guys are the same but some days my weldings rubbish and others its very good Today was one of those good days Bit of a blured photo, but im proud of the welding. The tines have always worried me a bit, only welded onto the main bar and maybe prone to bending if i hit something hard in the ground. More bit of box section welded from the bottom of the tines to the bottom of the main bar will do the trick, but i didnt fancy cutting 9 bits of box section all with different angle at one end <_< So i took the easy way out and welded a bit of angle iron across the bottom of the main bar. Now all the tine strengthening bits of box will all be the same For some strange reason thoughts then turned to mounting the harrow on the back of my 312-8. Swapping the clevis hitch over was easy, but a bit of ing was needed on the lifting cable front... or is it back The cable was sorted by using an old bike lock cable, one of those plastic coated steel cables you wrap around a lamp post, having remembered to loop it through the bike first By the time i thought about taking a photo of it, it was hung under the 312-8 so here's a photo of the off cut. One end of the new lift cable had a loop on it which was soon fixed to the bottom of the lifting handle the correct WH way, the other end was a bit more fun as it needs to attach onto the clevis hitch. Here's my solution, just feed the cable through and tighten the screws. And for now a few photo's More to come tomorrow morning with some testing photo's. Sorry to keep you all waiting, but my bed is calling. Share this post Link to post Share on other sites
Stigian 1,234 #18 Posted June 18, 2008 Good morning guys, I feel so much better after some much needed kip er... Chapter 3, Part 2 - Some fun and some bent bits As you might of guessed, with the harrow hanging on the 312-8 the tempation to give the harrow a test (even though its not finished) was to much to resist Test 1 was done on quite light dirt, not bad A lot more weight was needed to get the harrow to dig in well and not try and skip along the surface. Its very hard to take photo's while acting the part of the extra weight (Garry was driving), this is the best pic i managed The extra weight did wonders for the cutting depth so a harder challenge for the harrow was quickly thought up HHmmm.. loads of stones and rubble Of course something had to give seeing that i have not put all the strengthening on the harrow that i plan too. The good news is that it was only 3 of the cutting blade 's that got bent Right, wheres the big hammer? :) Share this post Link to post Share on other sites
T-Mo-(Moderator) 4,649 #19 Posted June 18, 2008 Ian, Always excellent narration. I was wondering about those knife tips bending or dulling over time. Maybe you need to also add a weight box to the mix? Looks good, though. Another great job and looking great. :whistle: Share this post Link to post Share on other sites
linen beige 15 #20 Posted June 18, 2008 Just a thought, What about adding a strip of narrow steel that runs vertically along the front of each "tooth"? Say, 1/4 inch thick x 1 inch ( insert metric equivalents.) or so wide. These would act as cutting adges AND reinforcing ribs. Share this post Link to post Share on other sites
nylyon-(Admin) 8,321 #21 Posted June 18, 2008 I need to get a new smiley for "We Want Video" just for you Ian! Seriously though, it looks great you may need your triangle thingies a little more stout though. Share this post Link to post Share on other sites
KyBlue 655 #22 Posted June 18, 2008 I think Jims idea of adding a verticle Rib from the center of each 'point' back to hte main arm, to act as a reenforcement Weight box...how about welding up a seat or two..haha Share this post Link to post Share on other sites
linen beige 15 #23 Posted June 18, 2008 Weight box...how about welding up a seat or two..haha Or at least some foot rests for the photographer. :whistle: Share this post Link to post Share on other sites
CasualObserver 3,411 #24 Posted June 18, 2008 Ian, instead of added on tips, what about cutting an inverted v in the bottom of each tine, and hammering/welding/grinding them into a blade at the bottom? I would think you wouldn't have to go very high, maybe an inch and a half? Any taller and you might start to get unstable. I'll see if I can come up with a picture of what I mean. Share this post Link to post Share on other sites
CasualObserver 3,411 #25 Posted June 18, 2008 Ok, I suck at drawing on the computer so don't laugh (too hard)... here's what I mean. What you're missing is the skinny knife-like edge to cut into the soil like a coulter does for a plow. Attached Image Share this post Link to post Share on other sites
