signboss 0 #1 Posted August 28, 2011 Hi I have a 310-8 runs good but stoped going I am sure that the drive belt/clutch needs adjustment can some help pics would be good thank you Share this post Link to post Share on other sites
Sparky-(Admin) 24,641 #2 Posted August 28, 2011 Can you give us more details? Is the engine running and the tractor not moving? Maybe the hi/low shifter is between positions. Even a stretched out worn drive belt should make the tractor move some. Mike........ Share this post Link to post Share on other sites
can whlvr 994 #3 Posted August 28, 2011 maybe you blew out the drive pulley key,or an axle key or one of the hubs is loose and the axle is spinning in the hub,or a shifter fork broke and your stuck in between gears,or check the shifter loch screw that holds the shifter lever in place,its right above the tranny where the shifter goes into the tranny,more info would be helpful Share this post Link to post Share on other sites
