jdog_kustoms 82 #1 Posted August 25, 2011 has anyone ever taken apart a eaton 11 or 7 and seen if it could be rebuilt or at least what all is inside it Share this post Link to post Share on other sites
buckrancher 2,697 #2 Posted August 25, 2011 I have a rebuid kit with o-rings and seals and a new input shaft for a #11 have not takin one apart yet does'nt look to hard just need to be clean it's not rocket science Brian Share this post Link to post Share on other sites
Brrly1 1,146 #3 Posted August 25, 2011 Jordan, from what I have heard #11 is rebuidable the #7 is junk but don't quote me. :banghead: Share this post Link to post Share on other sites
jdog_kustoms 82 #4 Posted August 25, 2011 i got a bad eaton 7 on my new zero turn i was gone take apart to see what it was like to rebuild ight have to do it some day my parts mower will keep me runnin for now brian is the kit a wheel horse or aftermarket kit Share this post Link to post Share on other sites
buckrancher 2,697 #5 Posted August 26, 2011 brian is the kit a wheel horse or aftermarket kit I got it thru toro Brian Share this post Link to post Share on other sites
kpinnc 18,492 #6 Posted August 29, 2011 I have a rebuid kit with o-rings and seals and a new input shaft for a #11 have not takin one apart yet does'nt look to hard just need to be clean it's not rocket science True, they are very simple internally- but each of the ball pistons on both the pump and drive side of the units are matched to the port they are in. Point being, when you take it apart you MUST keep them in the correct port. The manual recommends using a large rubber band around the carrier prior to taking it apart. If the ball pistons fall out, and you put them back in the wrong ports, you've got a paperweight. Good luck! Share this post Link to post Share on other sites
jdog_kustoms 82 #7 Posted August 29, 2011 i think that is what someone else did before me so i tryied to make them fit as nice as posible but i think i have a paper weight cuase when i took it apart some balls fell out some stuck in the holes Share this post Link to post Share on other sites
larry Chaffin 0 #8 Posted May 2, 2017 I need parts for my zero turn mower, 616, right rear hydro, gears, casing, etc.Contact me as soon as possible. Larrychaffin55@yahoo.com Share this post Link to post Share on other sites
