Operator 7 #1 Posted August 22, 2011 OK boys! Anyone help me on blade numbers for the 60" rear mount mower? Took blades off today to clean, inspect and get numbers off blades but there isn't any. Someone must know. Share this post Link to post Share on other sites
Cody 283 #2 Posted August 22, 2011 The Wheel Horse P/N for the blades is, 101682. Couldn't get over the price tho $114.40 :thumbs2: Share this post Link to post Share on other sites
C-Series14 15 #3 Posted August 22, 2011 Randy, I put Gator Blades on mine. I think I used a Woods RM59 mower for the blades. Let me look tomorrow and see if I can read some numbers. I will also look for the old blades... This sounds familiar, I think it was discussed somewhere before... Share this post Link to post Share on other sites
shorts 182 #4 Posted August 22, 2011 I took one of my blades to tractor supply and ordered a new set by measuring the blades according to the directions in the blade catalog,width,length,thickness and hole size. About $20 for each blade Share this post Link to post Share on other sites
Operator 7 #5 Posted August 22, 2011 Thanks Guys! This will get me started. I normally get all my blades through ASC but needed somewhere to start. Woods is still around so there shouldn't be a problem. I was thinking "Gator" blades to! heavier. Share this post Link to post Share on other sites
C-Series14 15 #6 Posted August 22, 2011 This is from a search, can't remember where I got them. They are Oregon mulching blades... 90-673 Oregon 20.187" Lawn Mower Blade-Woods LH C 90-673 Oregon 20.187" Lawn Mower Blade-Woods LH Cut Mulch Replacement Mower Blades for OEM Lawn Mowers Alternate Order, Brand / OEM Reference Numbers: Woods 23825, 31359, 6950, RM500, F35, RM59 Models Share this post Link to post Share on other sites
Operator 7 #7 Posted August 24, 2011 Thanks Mike that helps a lot :thumbs2: Share this post Link to post Share on other sites
pfrederi 19,376 #8 Posted August 24, 2011 I have used the oregon blades form Agri supply $10.49. http://www.agrisupply.com/mower-blade-wood...732/cn/6000128/ If you need a belt it is Woods 24004 and I got one from Vbelts for less for about $25 http://www.vbelts4less.com/ Seals for the spindles Woods # 5089 are National # 471762 or SKF CR #10740 Share this post Link to post Share on other sites
Operator 7 #9 Posted August 26, 2011 And a "thank you" to you Paul :thumbs2: Share this post Link to post Share on other sites
C-Series14 15 #10 Posted August 26, 2011 Thanks Mike that helps a lot No problem...glad to be able to help someone every once and awhile!!! :banghead: Share this post Link to post Share on other sites
