Steve in Mo
Tecumseh H60-75 carb
Steve in Mo
So I am pretty sure the carb for my engine is a 631828/631067 I see lots of numbers starting with 631 but not in the range of the next three. Most carbs say for H60 but somehow I wonder if that is enought.
Engine is Tecumseh H60-75 118E 614004906. As always your wealth of knowledge is appreciated. :woohoo:
Anglo Traction
Hi Steve, I can't help with locating a Carb for you, but you may try Brian (KB9LOR) in the Vendors Section.
Maybe someone more expert/familiar with Techy Carb substitutes will join in soon?.
I can't find spec #75118E listed, but found 75118F,G and H. Irrespectively, they and many many others all use the same Series 1 Carb #631828 which supercedes #631067A.
Hope you find what you need.
on the H60 75117H in my 1968 lawn ranger i used a replacement carb from Oregon Power Equipment. part # 050-646. it bolted right up , choke and throttle levers were in the correct place , and the motor runs great
got it here for $35
http://www.psep.biz/store/tecumseh_carburetors.htm
