Octim1985 0 #1 Posted August 16, 2011 what is the best way to stop the front end of my 266h from slipping around. I thought about weight and maybe chains. Share this post Link to post Share on other sites
rmaynard 16,349 #2 Posted August 16, 2011 What are they slipping on? What type of tires do you have? Share this post Link to post Share on other sites
wallfish 18,195 #3 Posted August 16, 2011 This is the cheapest and easiest solution. #40 roller chain less than $20. Easy on and off. Share this post Link to post Share on other sites
KC9KAS 4,744 #4 Posted August 16, 2011 Put some fluid in the front tires. Share this post Link to post Share on other sites
Octim1985 0 #5 Posted August 17, 2011 I have no idea what type of tires I have Im pretty sure there are the ones it came from the factory with. They seem to slip when I make a tight turn. And what happens is I turn the wheel and the tractor just keeps going straight. Share this post Link to post Share on other sites
rmaynard 16,349 #7 Posted August 17, 2011 I have no idea what type of tires I have Im pretty sure there are the ones it came from the factory with. They seem to slip when I make a tight turn. And what happens is I turn the wheel and the tractor just keeps going straight. Look on the sidewall of the tires. The brand and name is there. You say they slip when you make a tight turn. Are you turning on grass, gravel, pavement or what? Is the surface dry or wet? Share this post Link to post Share on other sites
Octim1985 0 #8 Posted August 17, 2011 they slip in dry grass, wet grass, and on wet pavement Share this post Link to post Share on other sites
wallfish 18,195 #9 Posted August 17, 2011 Sounds like something in the steering components, not the tires. Post some pics Share this post Link to post Share on other sites
rmaynard 16,349 #10 Posted August 17, 2011 I would suggest checking the front end alignment. You could have something out of adjustment. If you need a service manual, I have an excellent quality manual in .pdf format that I can email to you. PM me with your email address and I will send it to you if you need it. Bob Share this post Link to post Share on other sites
Duff 206 #11 Posted August 17, 2011 I'm with John on this one. Possibly the gears aren't meshing properly where the steering shaft meets the fan gear - this is not altogether uncommon (assuming the 200-series has a similar steering set-up to the 200's and 400's?). When you turn all the way one way or the other does the steering wheel continue to turn but the tires don't do anything? Duff :D Share this post Link to post Share on other sites
Redbirdman 7 #12 Posted August 17, 2011 check your differential....... Share this post Link to post Share on other sites
Octim1985 0 #13 Posted August 22, 2011 Thanks for the good suggestions Share this post Link to post Share on other sites
rmaynard 16,349 #14 Posted August 22, 2011 Be sure to let us know if you find out what the problem is. Share this post Link to post Share on other sites
