lobo 22 #1 Posted August 15, 2011 I have a troy-built tiller junior that needs the fuel line changed, what I need to know is do you have to take the tin off the front to get to it of does it just slip in and out? If you have to take the tin off does anyone know the order you have to torque the head bolts and the poundage of them? Share this post Link to post Share on other sites
TT-(Moderator) 1,169 #2 Posted August 15, 2011 #1 priority with these is to make sure that the new line you plan to install is not too big for the holes in the blower housing. My "trick": Get a coat hanger and cut the long straight piece off the bottom. Remove the old hose and insert the coat hanger wire in through one hole of the blower housing and out the other. Slide the new hose over the wire until it comes out the other side of the blower housing. Remove wire from inside hose. Share this post Link to post Share on other sites
lobo 22 #3 Posted August 15, 2011 Thank you very much TT, will give it a try. Share this post Link to post Share on other sites
Buzz 502 #4 Posted August 15, 2011 Here's the manual you need for the torque specs. http://toprake.com/index.php?module=docume...e&JAS_File_id=2 Share this post Link to post Share on other sites
lobo 22 #5 Posted August 16, 2011 Thank you Buzz, was searching for the manual yesterday and it kept sending me to more places to look, never did find the manual. Not good at this computer stuff .... :woohoo: Share this post Link to post Share on other sites
