JUSS10 250 #1 Posted August 13, 2011 a few months back i had gone over to my grandpas to turn over his driveway and pull some of the weeds with a make shift harrow i had built. ever since then any time i would go over he brings that up. He has quite a large barn and as my collection grows, a few of my tractors end up over there. every time i would bring one over to store, he asks if i have one for him. well one day i went over while they were gone and brought a 654 home. its pretty much all there, steering is decent, all original with very little "vandalism" to it. brought it home, rebuilt the carb and actually got that old techumseh running pretty good. checked the fluids, changed out the seat, found a set of AG tires, rewired it, loosened up the stuck cables and got it up and running pretty good! i also went and snagged his sprayer last week that i put together to put on the back of his lawn mower, he didn't like it much on the back cause he was a afraid he'd break off the sprayer boom not seeing where it is. That said, i made a quick attach bracket for the front of the tractor and mounted the sprayer up on the front. put the make shift rake on the back and now he has quite the machine to do driveway work with! I'm pretty excited to bring it over tomorrow. not to bad for getting thrown together in a few days, he should really like it Share this post Link to post Share on other sites
WheelHorse58 1 #2 Posted August 13, 2011 Thats pretty interesting nice job on the sprayer! Share this post Link to post Share on other sites
HorseFixer 2,014 #3 Posted August 13, 2011 Nice machine Justin he should be happy with that! ~Duke Share this post Link to post Share on other sites
Duff 206 #4 Posted August 13, 2011 That's quite a set up, Justin - nice work! Out of curiousity, how much liquid can he put in that sprayer tank without the rear end coming off the ground? Duff :D Share this post Link to post Share on other sites
Kelly 1,037 #5 Posted August 13, 2011 I like it, just watch what is used in the sprayer, as he will be driving right though the mist. Share this post Link to post Share on other sites
JUSS10 250 #6 Posted August 13, 2011 thanks everyone! as for how much it can hold before it gets tipsy, i haven't tried yet, but if it becomes an issue i have a set of concrete wheel weights i cast a while back that i could bolt on. Kelly, thats a great point, he uses it for weed killer, right now the mist really isn't bad at all, the nozzles pretty much shoot straight down, if it becomes an issue i can move the boom lower to the ground. worse case, it will get moved to the back like the sprayer i built for my 854 Justin Share this post Link to post Share on other sites
Gene_S 93 #7 Posted August 13, 2011 I like it, just watch what is used in the sprayer, as he will be driving right though the mist. Very, very, very good point Kelly!!! As for the tractor Justin your being a "great" grandson and memories are priceless... :woohoo: Share this post Link to post Share on other sites
stevebo-(Moderator) 8,604 #8 Posted August 13, 2011 It is great to see you taking care of grampa. He will remember it !! Share this post Link to post Share on other sites
massey 119 #9 Posted August 13, 2011 Nice job helping out your grandfather like that. Share this post Link to post Share on other sites
ol550 844 #10 Posted August 13, 2011 Looks like it might work, but how well does it steer? Next how long can it run the pump before the battery goes flat? Mike Share this post Link to post Share on other sites
JUSS10 250 #11 Posted August 13, 2011 steers just fine. battery charges with no problem, been running sprayers on my round hoods since I've had them with no issues. charging system seems to be working just fine to me. Share this post Link to post Share on other sites
shorts 182 #12 Posted August 13, 2011 :woohoo: sweet machine from the info that I've seen on weed killers you want large droplets that fall instead of a fine mist that floats on the air so that you only apply chemical where you want it and not in the flower beds Share this post Link to post Share on other sites
JUSS10 250 #13 Posted August 13, 2011 the nozzle on here aren't misting nozzles, they offer a constant spray. it works quite well when he had it behind his old tractor, just wants to see where he is spraying so i mounted it on the front of this one. Share this post Link to post Share on other sites
Retired Wrencher 6,452 #14 Posted August 13, 2011 :woohoo: Justin nice job very nice R/hood . Every time I see a project like this when it involves Family and generations and hand down to the next it reminds me of this picture because this in my book is what it is all about. Gary B............... Share this post Link to post Share on other sites
JUSS10 250 #15 Posted August 13, 2011 well i think he liked it! brought it over this afternoon and at first he thought it was just another tractor that i needed him to store. it was once he saw his sprayer on the front that he put it all together. he just couldn't believe it was for him! he sat down and said it brought back memories of the old farmall A he used to own, just a lot smaller and more practical for the current house he hopped right on and started to rake up the driveway. I have a feeling he'll get a lot of seat time on this machine and find as many uses as possible to drive it i didn't have my good camera so all i have is cell phone pics, but i figured these will do Justin (and i did do a voltage check, the 3 Amp charging system can't quite keep up with the sprayer so he'll have to use it in moderation, at least the engine doesn't use a coil that requires the battery to run) Share this post Link to post Share on other sites
New-To-Red with C-195 1 #16 Posted August 13, 2011 Great job! I took a car battery and mounted on the back of my Kaw Mule that runs my sprayer. It will run the sprayer many times before it needs charged again too. Many times you can go to an auto parts store with a volt meter and they will let you purchase the ones people return as cores too! Then they only cost you about $7. :woohoo: Share this post Link to post Share on other sites
can whlvr 994 #17 Posted August 14, 2011 this is a great story,i would imagine your granpa is a very proud grandfather :woohoo: Share this post Link to post Share on other sites
shorts 182 #18 Posted August 14, 2011 looks like a happy man with a super grandson, :woohoo: Share this post Link to post Share on other sites
corn53 4 #19 Posted August 16, 2011 Awesome job and I love that Grandpa will be using it!!! Nothing better than taking care of family!!! :woohoo: Share this post Link to post Share on other sites
dkopp 1 #20 Posted August 16, 2011 That is a neat setup you did there. Share this post Link to post Share on other sites
Coadster32 793 #21 Posted August 16, 2011 Very nice!! Making Grampa happy is a wonderful thing. Share this post Link to post Share on other sites
