kadetklapp 1 #1 Posted August 12, 2011 Now that I've been running my tractor for a couple of weeks, I've noticed it is badly down on power. With the deck engaged and pulling a slight incline, the tractor will stall if you do not either back off the hydro or shut down the mower. Plugs are in good condition, new coil with wires, good fuel, and the carb seems to be opening up correctly and isn't gunked up or anything. I was told by the PO that the motor had a "partial rebuild" several years ago but I don't know what all was done to it. My buddy thinks the valves may need adjusted. The motor acts like its "loading up" under stress. I've greased my pulley's and everything seems to be turning OK. Any ideas? Share this post Link to post Share on other sites
can whlvr 994 #2 Posted August 12, 2011 sounds like you need to do a compression test or a leak down test,you can look in the search area or google leak down test,im not very knowagageable of the briggs,i cant tell you if it has the compression release for starting,if it does then compression test is a little harder to do unless you have another tractor to hook up to the pto with a belt ina figure 8 and use the second tractor to turn over the briggs,could be carbon on the valve seats not letting the valves close all the way,you have to pull the heads to check that,unless you have one of those fancy cameras thet can go in the spark plug hole Share this post Link to post Share on other sites
kadetklapp 1 #3 Posted August 12, 2011 Ok that's sort of what we were thinking as well. I'm thinking this is a good excuse to do a ChiCom diesel conversion, but the wife unit isn't buying it yet...lol. Share this post Link to post Share on other sites
Save Old Iron 1,573 #4 Posted August 12, 2011 also check both cylinders are hot if one is only warm, you might be running on only one cylinder. Share this post Link to post Share on other sites
kadetklapp 1 #5 Posted August 12, 2011 also check both cylinders are hot if one is only warm, you might be running on only one cylinder. That was something else I was wondering, I might have a dead cylinder. Share this post Link to post Share on other sites
mavfreak 11 #6 Posted August 14, 2011 These briggs are prone to car boning up also. Might want to pull the heads and clean off the deposits while in there you can check the cylinders and valve and valve seats Share this post Link to post Share on other sites
Shuboxlover 484 #7 Posted August 14, 2011 If this Briggs is like the one on my GT-1642, you might want to check the "fuel pump" diaphragm in the carb, mine was pretty brittle and it would kind of act like you are describing when it was under load. A rebuild kit for the carb fixed my problem. Share this post Link to post Share on other sites
kadetklapp 1 #8 Posted August 15, 2011 Will do. I bought a can of Seafoam yesterday to try also, just to see if it peps up a bit. Share this post Link to post Share on other sites
kadetklapp 1 #9 Posted August 16, 2011 Seafoam is no dice. I noticed the thing has a pretty severe "spark knock" type sound to it, and at idle, it is missing and backfiring pretty bad. Share this post Link to post Share on other sites
mavfreak 11 #10 Posted August 16, 2011 If that is the case then i would say its a very good chance that its carbon ed up. You'll have to pull a head to check, so you'll need a head gasket. If it is carbon then you'll need to clean it with some solvent like break clean or carb cleaner. and a wire brush. While you have head off look at the valves close also and make sure one (usually the exhaust is burnt or has a hole in it). Just something you can try. It has work for me on briggs twins. Share this post Link to post Share on other sites
kadetklapp 1 #11 Posted August 18, 2011 Ok, thanks for the info. Share this post Link to post Share on other sites
kadetklapp 1 #12 Posted August 22, 2011 Well it seems the Seafoam helped out a lot with it's idling and start-up power, but I'm still having to back off the stick to keep from stalling it when pulling any kind of incline and mowing at the same time. I'm not sure now if it's the motor, or if the PTO is hanging up. Share this post Link to post Share on other sites
