Calebintn 1 #1 Posted August 12, 2011 Guys my 854 has some real wiring issues but I dont want do the rewire until after the restore. Is there a way to direct wire the coil so I can test run the engine before I start the restore? :woohoo: Share this post Link to post Share on other sites
Save Old Iron 1,563 #2 Posted August 12, 2011 a jumper wire from the battery (+) terminal to the ignition coil (+) and a jumper from the battery (-) terminal to the case of the engine will make it possible to activate the ignition system without any further connections. Share this post Link to post Share on other sites
Save Old Iron 1,563 #3 Posted August 12, 2011 and of course remember to disconnect the power to the coil when you are finished :woohoo: Share this post Link to post Share on other sites
