meadowfield 2,945 #1 Posted August 9, 2011 what these blocks are for? can't see them on the toro part viewer, so assume they have been made up for a reason ! I can see the holes line up with the original plough frame holes, but can't work out why they were needed. They came with a 96-42BC01 plough. thanks mark Share this post Link to post Share on other sites
rmaynard 16,754 #2 Posted August 9, 2011 Looks like additional weight to keep the blade down. Are they heavy? Share this post Link to post Share on other sites
meadowfield 2,945 #3 Posted August 9, 2011 Looks like additional weight to keep the blade down. Are they heavy? relatively... they will weigh 8lbs each, but hardly enough to keep the blade down - plus they mount on the rear - or it looks that way. thanks Share this post Link to post Share on other sites
Anglo Traction 761 #4 Posted August 9, 2011 Well done Mark, Couple of nice aquisitions there!. You can do some serious work with those. Can't help with the Plough I'm afraid. Share this post Link to post Share on other sites
rmaynard 16,754 #5 Posted August 9, 2011 Looks like additional weight to keep the blade down. Are they heavy? relatively... they will weigh 8lbs each, but hardly enough to keep the blade down - plus they mount on the rear - or it looks that way. thanks Every little bit of weight in the rear when plowing snow is helpful, but 16 lbs hardly seems like it would do much. I'm curious to see what others think. :woohoo: Share this post Link to post Share on other sites
IthacaJeff 151 #6 Posted August 10, 2011 If they match up with the holes on the rear of the snow plow frame then it seems they would have been made to fit there. Perhaps to give weight to the rear tires for traction, but as others have said, 16 lbs is not worth the effort. (perhaps they are 16 kilos?). Also, after being fitted into the rear axle attach-a-matic it seems that these weights would not fit. Perhaps the plow was fitted to a non-WH tractor with the plow frame attachment point was somewhere nearer the middle -- and these weights could then serve as counter weights to the weight of the plow blade. Just a thought. Jeff in Enfield NY Share this post Link to post Share on other sites
whfan74 2,073 #7 Posted August 10, 2011 They are almost like the blocks that go on the tranny along with the rear hitch that holds the blade. Allows for you to have a blade that rides a little higher off the ground when cruising around. Share this post Link to post Share on other sites
