krazy_horse 59 #1 Posted August 9, 2011 The slot hitch cable on my 856 is broken. I was out at tractor supply yesterday and they have cable and clevis ends which look a lot like the ones on the wheel horses. My question," Can one be made up and how would you crimp the ends to stand up for the lifting needed"? Thanks, Jim :woohoo: Share this post Link to post Share on other sites
jbumgarner 12 #2 Posted August 9, 2011 I made mine with a cable from my local hardware store. I used a swag tool and crimped stops to the ends and have had no problems. I just posted on this subject last week. Good luck :woohoo: Share this post Link to post Share on other sites
can whlvr 994 #3 Posted August 10, 2011 if you dont want to buy yhe crimping tool you can use cable clamps,you can buy them at any harware store Share this post Link to post Share on other sites
doc 0 #4 Posted August 23, 2011 went to a cable and chain company few years ago and they made one up for me also just remembered a friend of mine works for a crane company ill talk to him this weekend to see if he can make one up Share this post Link to post Share on other sites
stevebo-(Moderator) 8,602 #5 Posted August 23, 2011 Most of the hardware stores can make up any size you want and crimp the ends for you. I believe you should have them crimp one end since the other end needs to go through the cable tube. I would just use the u bolts on that end under the tractor. Share this post Link to post Share on other sites
obie130 0 #6 Posted March 30, 2012 hi, my ift cable broke for my slot hitch sometime over the winter plowing, my question is i bought a new cable but not sure which hole to connect it o on my lift arm. if someone has a pic r any info that can point me in the right direction it be greatly appriciated Share this post Link to post Share on other sites
gwgdog66 23 #7 Posted March 31, 2012 hi, my ift cable broke for my slot hitch sometime over the winter plowing, my question is i bought a new cable but not sure which hole to connect it o on my lift arm. if someone has a pic r any info that can point me in the right direction it be greatly appriciated Most of the ones I've used connect to the hole at the end of lift arm. Check out this topic about half way down. it has a parts blowup. Share this post Link to post Share on other sites
