pfrederi 19,375 #1 Posted August 7, 2011 I am working on a 48inch SD deck. 15-48SC01. When you look it up on Toro's website the parts listing covers both 42 and 48 SD decks. It will list two different part numbers but doesn't say which deck each number fits. For instance the "Special washer" (The one on top of the blade item#33) shows 2 part numbers 920257 and 920258 but doesn't say which goes to which deck. This is true for several other parts. Is there a way if figuring out which part is for which deck??? Share this post Link to post Share on other sites
gwest_ca-(File Mod) 11,875 #2 Posted August 7, 2011 Try http://www.partstree.com/parts/ Type Toro in the 2nd box and the 15-48SC01 model number in the 3rd box. Usually this site does a better job of identifying the models which they have done with the washers. Garry Share this post Link to post Share on other sites
pfrederi 19,375 #3 Posted August 7, 2011 Gary: Thank you so much. It is much easier to figure out than the Toro site... To bad the washers for the 48" Deck are $3 vs 35cents for the 42" :woohoo: Share this post Link to post Share on other sites
