kitkit 137 #1 Posted August 5, 2011 Hello, need a little help telling me what I have here , what is correct and incorrect .I can't post a picture it seems but if I get an email address from someone willing to help I will send the pictures that way . Thank you . My Email is bkindig@msn.com Share this post Link to post Share on other sites
JimD 3,347 #3 Posted August 5, 2011 This post will show you how to post pictures... http://www.wheelhorseforum.com/index.php?showtopic=1071 Share this post Link to post Share on other sites
rmaynard 16,873 #4 Posted August 5, 2011 :woohoo: PM sent Share this post Link to post Share on other sites
rmaynard 16,873 #5 Posted August 6, 2011 As promised, here are your pictures. Share this post Link to post Share on other sites
can whlvr 994 #6 Posted August 6, 2011 good lookin tractor,so did the rjs not have a gear shifter,was it basically one speed other than the throttle control? Share this post Link to post Share on other sites
chazm 413 #7 Posted August 6, 2011 Hello & Chaz :woohoo: Share this post Link to post Share on other sites
stevebo-(Moderator) 8,604 #8 Posted August 6, 2011 That is an RJ35 however it has had some "modifications" oer the years. Pulley system is wrong and the hitch in the back is not suppose to be welded to the round part of the frame. Wrong steering wheel, missing belt guard, the front rims have been replaced with newer ones, exhaust stack is not correct. I cannot confirm if the engine is correct Either way it is a 35 :woohoo: Share this post Link to post Share on other sites
TT-(Moderator) 1,169 #9 Posted August 6, 2011 I'd say the engine is a mid to late 50's B&S model 6 (guessing) and is definitely incorrect. The stamped frame (vs. channel iron) dates the chassis from (potentially) very late 1955 to early/mid 1956. (but don't take that to the bank either ) Share this post Link to post Share on other sites
kitkit 137 #10 Posted August 10, 2011 Hello, I would like to thank everyone for the welcome and information on the tractor especially Rmaynard for taking the time to post the pictures for me when I was unable to . Thanks to all . Share this post Link to post Share on other sites
Ken B 3,202 #11 Posted August 11, 2011 Nice tractor you have there. That exhaust stack looks right at home on it! Share this post Link to post Share on other sites
buckrancher 2,695 #12 Posted August 11, 2011 good lookin tractor,so did the rjs not have a gear shifter,was it basically one speed other than the throttle control? only pre 1958 (rj35/25) they used a variable belt drive but this ones missing the vari-drive pulley you changed speed by moving the long lever on the side in to a different hole the vari drive uses two belts and by changing the hole that the lever is in one side of the vari-drive pulley will get a larger dia. and the other side will be a smaller dia. thus Changing the tractor speed. To reverse you pull the lever all the way back to engage a fiction disk off the motor pulley to the vari drive pulley Brian Share this post Link to post Share on other sites
