WHorse1054 2 #1 Posted August 3, 2011 i have an 1968 electro 12 and i want to put an plow on it. so my questions are what size?, short from or long frame? if anyone has pics of what it looks like that will have me an lot because there always on Craigslist in ct. Thanks, Mitch Share this post Link to post Share on other sites
kadetklapp 1 #2 Posted August 3, 2011 There is a thread addressing this subject which I was referred to, but it didn't answer my question either. It depends on the length of the frame on the blade and the length of your tractor. Also some require a rear bracket. Link- http://www.wheelhorseforum.com/index.php?showtopic=30278 Share this post Link to post Share on other sites
CasualObserver 3,411 #3 Posted August 3, 2011 Mitch, Your Electro is a long frame tractor, you need a 42" wide blade on a frame that looks like this. (taken from this thread... http://www.wheelhorseforum.com/index.php?showtopic=541 ) You could use a 48" too if that's what you find/want, but the 42 is right. You also need the rear hitch that bolts around the axle tubes like this. Share this post Link to post Share on other sites
fourwheels0 191 #4 Posted August 3, 2011 here's my old electro 12 with a 42 inch blade and long frame. Share this post Link to post Share on other sites
WHorse1054 2 #5 Posted August 3, 2011 thanks this helps an lot. here's my old electro 12 with a 42 inch blade and long frame. Reduced Image - Click to see full size nice. now comes the task of finding one Share this post Link to post Share on other sites
can whlvr 994 #6 Posted August 4, 2011 the long frame blades are pretty popular so you should find pretty easy Share this post Link to post Share on other sites
