Lawn Ranger kid 14 #1 Posted August 3, 2011 Can I use a mechanical fuel pump on an 8hp kohler with a pulse pump. Or would it not work because of the cam. Thanks Josh Share this post Link to post Share on other sites
Horse'n Around 22 #2 Posted August 3, 2011 As long as the cam in your engine has the lobe for the fuel pump you will be fine. When you remove the pulse fuel pump, take a peek inside the hole in the block and you should be able to see the lobe on the cam shaft. I have been told that there are some engines that have cams that do not have the lobe for the fuel pump but so far all of mine have the lobe present on the cam shaft. John Share this post Link to post Share on other sites
can whlvr 994 #3 Posted August 4, 2011 if not an electric fuel pump is a good option too Share this post Link to post Share on other sites
