fourwheels0
kohler 8hp fuel issue
fourwheels0
my (grey block) 8 hp kohler (in a c-81) will idle fine but in order to give it more throttle to run i have to have the choke on some.
it throttles up fine and seems to run great but only with the choke on maybe 1/4 to 1/2 way.
it has sat for a while without running when i got it.
is this the sign of a carb problem? or maybe the fuel pump?.
i plan on changing the fuel lines,put in a fuel filter ect.
where should i start looking to correct this issue besides what i plan to do.
thanks.
Coadster32
Not sure if you cleaned the carb yet, but it usually is a great place to start. If it will run on partial choke, then I doubt it's your pump. You could just try to richen the main a bit, and see if you don't need the choke. Good luck.
fourwheels0
sure enough the carb just needed to be cleaned.
purrs like a kitten now :D .
or should i say pant's like a pony? :woohoo: .
