71_Bronco 1,073 #1 Posted July 28, 2011 So I was thinking last night. I bought a grader blade to use with my Bronco. I will be using it to fix my parents 900 foot long gravel driveway, as it is hilly and gets the wash-board effect all the time. My dad usually uses a rear-mount york rake on his bigger Kabota. So I was thinking. The grader blade will work, but the blade will tend to scrape and push rather then just fill and level like the york rake. I do not have the 3 point set-up on the back of my Bronco, so I cannot use the york rake from the Kabota. So I thought, what if I made something similar to a grader blade mount, then put flexible "teeth" on it like a york rake. This way I can still use the up and down like the grader blade, but not be as aggressive with gravel moving. Do you guys think it will work? Pro's & Con's? Share this post Link to post Share on other sites
jusjeepn 59 #2 Posted July 28, 2011 I think you will have a hard time finding anything short enough and strong enough with flexability to be as effective as a York rake. The fingers could only be approximately as long as your grader blade is tall. You would be creating the first "Grader Sieve". It would probably make for some interesting design in the drive though! :woohoo: Share this post Link to post Share on other sites
TT-(Moderator) 1,173 #3 Posted July 28, 2011 I would keep using the Kubota. :woohoo: Share this post Link to post Share on other sites
WheelHorse_of_course 101 #4 Posted July 29, 2011 A york rake works much better than a blade for what you are doing, no doubt about that. You can buy blades from a farm store or catalog (email me if you need source) but they need to be long enough to flex, as mentioned above. :woohoo: Share this post Link to post Share on other sites
shootinok 15 #5 Posted July 29, 2011 you could get one that drug behind that didn't require a 3pt. check this out... http://www.newhavenpower.com/YorkTA1.html Share this post Link to post Share on other sites
Duff 207 #6 Posted July 31, 2011 DR Power Equipment makes an interesting unit as well...... http://www.drpower.com/Power-Grader.aspx?c...jCV7qj4zbEj1bEL They say it can be dragged behind an ATV, so it should work behind a ! Duff :woohoo: Share this post Link to post Share on other sites
HorseFixer 2,015 #7 Posted July 31, 2011 you could get one that drug behind that didn't require a 3pt. check this out... http://www.newhavenpower.com/YorkTA1.html Pretty Neat! Cheers ~Duke :D Share this post Link to post Share on other sites
jusjeepn 59 #8 Posted July 31, 2011 I have the York TA1 with the optional grader attachment. It works very well in a large area. I have never used the grader attachment since I have one for the tractor so I really can't tell you how well it works. This is probably the only attachment that I'll never part with! Share this post Link to post Share on other sites
