kodiak 5 #1 Posted July 27, 2011 i have a 310-8 belive to be a 1985 but i cant find the model nuber could someone please help me Share this post Link to post Share on other sites
TT-(Moderator) 1,162 #2 Posted July 27, 2011 Go here: https://lookup3.toro.com/partdex/index.cfm?...es&xCaller=Toro ("advanced search") Select "1985" from the list in the third box down and type "310-8" in the fourth box down. ("Product Name") Share this post Link to post Share on other sites
kodiak 5 #3 Posted July 27, 2011 That was helpful with a model number for an 85 310-8 but im not sure if that is the year i have where would the tag be on the tractor. Its not under the seat or on the riser for the dashand i didnt see it on the frame either Share this post Link to post Share on other sites
puddlejumper 67 #4 Posted July 27, 2011 Nick, on my 308 its justa sticker on the seat pan just below and to the front of the seat, Mines wore away and half gone. So yours may be missing totally. Share this post Link to post Share on other sites
kodiak 5 #5 Posted July 27, 2011 Mitch believe your right there is a sticker there but i cannot read it Share this post Link to post Share on other sites
gwest_ca-(File Mod) 11,750 #6 Posted July 27, 2011 The 1985 310-8 model 21-10K801 was the only model to use a K241S with a 46849 spec number. What is your's and the engine serial number? Garry Share this post Link to post Share on other sites
kodiak 5 #7 Posted July 28, 2011 That is the other problem the engine has been swapped with a k301 by the po Share this post Link to post Share on other sites
tunahead72 2,581 #8 Posted July 28, 2011 Nick, The fact that your sticker is located in front of the seat actually narrows things down a good bit. For the 1987 models, the stickers moved to the left side of the seat, and I'm guessing they stayed there in later years. The 1985 models had a silver stripe on the hood, like the one in this thread: http://www.wheelhorseforum.com/index.php?showtopic=30167 The 1986 models had more of a red/maroon stripe on the hood, like the ones on these 1987 models: http://www.wheelhorseforum.com/index.php?showtopic=4904 Which is not to say the PO didn't swap the hood as well.... <_< Are you certain the engine is a K301? Is there actually a sticker on the shroud that identifies it as a K301? Share this post Link to post Share on other sites
kodiak 5 #9 Posted July 28, 2011 The for the help yes my sticker is in the middle in front of the seat and it has a moroon stripe with silvr letters so i guess that would make it an 86 and yes the shroud has the original sticker labeled k301 Share this post Link to post Share on other sites
kodiak 5 #10 Posted July 29, 2011 here this should help and take alot of guessing out of this problem Share this post Link to post Share on other sites
tunahead72 2,581 #11 Posted July 29, 2011 The for the help yes my sticker is in the middle in front of the seat and it has a moroon stripe with silvr letters so i guess that would make it an 86 and yes the shroud has the original sticker labeled k301 That's my guess too. The kicker is, there were actually TWO model numbers for the 1986 310-8's: 21-10K802 and 21-10K803. There's another thread here that touches on that fact -- you'll have to wade through a lot of other stuff (all 310-8 related) to get there, or you can start reading at my post on 4/22/11: http://www.wheelhorseforum.com/index.php?showtopic=27508 Bottom line, the two model numbers are nearly identical, the only exception I've ever seen being the transmission case and inner axle bearings. If anybody else knows differently, feel free to fill us all in here. -------- Just saw your photo, looks like an '86 to me. Other than the engine, the only thing that looks different is the seat, probably a replacement? Share this post Link to post Share on other sites
rmaynard 16,589 #12 Posted July 29, 2011 What's the spec number on the engine? Look to be from an earlier model since it is red. Share this post Link to post Share on other sites
