smokin joe 31 #1 Posted July 24, 2011 Just like it reads I dont what model it is.Could be a tough one wrong engine wrong color so on..If anyone could help it would make my day..And it also needs a steering arm but I dont know model will work?Thanks Share this post Link to post Share on other sites
Kelly 1,035 #2 Posted July 24, 2011 It's a 1962 something with a newer kohler in it, only ones it could be are a 702, 502 or 552. I bet it goes like hell with that big pulley on the engine :woohoo: Share this post Link to post Share on other sites
smokin joe 31 #3 Posted July 24, 2011 The p/o said it went around 40mph :woohoo: Share this post Link to post Share on other sites
312Hydro 474 #4 Posted July 24, 2011 The p/o said it went around 40mph That would be one wild ride! Share this post Link to post Share on other sites
neil 2,415 #5 Posted July 24, 2011 would that be a 701 plastic dash fitted on the tank nice looking tractor when its the right colour Share this post Link to post Share on other sites
squonk 44,947 #6 Posted July 24, 2011 Whoever did that to that tractor should be court-martialed, shot. and sent to the Russian front!! :woohoo: Share this post Link to post Share on other sites
buckrancher 2,695 #7 Posted July 24, 2011 It's a1962 It has the right front end ,steering wheel ,hood and metal bolt on dash but as Kelly said it could be a 702,502or552 I believe that the battery box was still a weld on in 62 but the one on that tractor has been removed and two piece's of angle iron put in it's place I would guess a 702 or a 552 as there is a amp meter and key start the 502 would have a on off toggle switch where the amp meter is Brian Share this post Link to post Share on other sites
smokin joe 31 #8 Posted July 24, 2011 Is the steering arm the same for the 552 and 702?Thanks Buckrancher :woohoo: Share this post Link to post Share on other sites
Raider12 13 #9 Posted July 24, 2011 The p/o said it went around 40mph Wow! 40 mph I would have hated to been on that tractor when the steering arm broke or fell off? :D Share this post Link to post Share on other sites
buckrancher 2,695 #10 Posted July 24, 2011 Is the steering arm the same for the 552 and 702?Thanks Buckrancher should all be the same front end. looks like she's missing the two support bars (#3930) that run from the steering support to the hoodstand and I see the shift lever is bent for a hy-2 kit so she should be a later year 1962 as the early ones had a straight lever like the 701's,rj's etc. Brian Share this post Link to post Share on other sites
smokin joe 31 #11 Posted July 24, 2011 Thanks Guys .They had the front axle flipped upside down and I'm trying to put it together the right way.I will probably leave it green for a while unless I can come up with an old style 7hp Kohler to throw on it. Share this post Link to post Share on other sites
stevasaurus 23,521 #12 Posted July 24, 2011 Joe...I am going to guess 702, because you do not see many 552's. Neither the 702 or the 552 would have the tool box because of the battery. The shifter is the one for the HY-2 kit. The kit could have been ordered standard, but the kit came with the bent shifter to replace the straight one, if it was ordered later. They usually went on the 702. All the parts for the 1962's are the same except for the belt guard...basically...depended on weather it was a Tech/Lawson 5.5HP or the Kohler 7HP. The color tells me the last owner was into MOPAR Superbees from the late 1960's. At 40mph, you can put plates on it and drive it back and forth to work. Nice horse Joe. :woohoo: Share this post Link to post Share on other sites
TT-(Moderator) 1,169 #13 Posted July 24, 2011 Yep - I say it's one of these : Unfortunately, there is nothing left that can provide positive identification of exactly which one though. Later '62 models came "standard" with the two-bend shifter. I believe only the instructions to add the second bend in the earlier shifters were included with the HY-2 kit. Share this post Link to post Share on other sites
