COORSUSA
rj 58 59
COORSUSA
hello. very close to getting my rj running.. someone had previously slotted the engine mount holes. -very bad job-..I have made a plate to cover up the huge slots. i need some help for referance holes. does anyone have a way to measure holes for motor? i want to use correct belt so exact hole possition is needed.. if anyone had pics . with measurements. that would be great. thanks
MikesRJ
I have an RJ frame in primer out in the shed. If I can get out there today I'll get you some measurements.
I do have a suggestion for you though. I would recommend you not use the plate. I would have the frame holes welded over, grind both sides flat, then re-drill the holes to original spec. Modifying it is not a good idea. Fixing it correctly is a much better approach. Just my two cents.
MikesRJ
