fdsinozich
Repower
fdsinozich
My Tecumseh is knocking slightly and I am anticipating a change in the near future. I had to find some parts a while back and in the process I found that Tecumseh went out of business two years ago. I want to go with another manufacturer for that reason. Any suggestions that will bolt up without any modifications?
Thanks,
Frank
tommy3horse
Go with a Kohler K301, a direct bolt in.
Tom
:woohoo:
Buzz
Tom
:woohoo:
I'm pretty sure that the ignition switch and electricial system need to be changed.
bigd
the shop i work at is a tecumseh dealer i can assure you they are not out of business.they were bought by lauson but they are continuing production and parts.that said put a kohler on it which is what should be on a c120 if i read this post correctly. :woohoo:
Buzz
The 1974-75 C-120s came with either a Tecumseh or a Kohler engine for some strange reason. They are similar but not the same and there are differences you should be aware of before swapping brands of engine.
bigd
that is strange i have yet to meet a techy fan.and i learned something i didnt know that was an option on the c's was it just the 120 or all of them?
gwgdog66
All the literature I can find was the 74 and 75 C-120's like Buzz said.
fdsinozich
Thanks for all the posts.
Frank
rwilson
the C series in 74-75 with the Tecumseh engines were called "special". it was printed on the decal under the C-120. So instead of the word 8 speed it said Special. I have seen the C160 special as well.
