DMK855
Engine question....
DMK855
Will the K 301 off of a Gravely 812 Tractor work on an Electro 12?? Is the PTO side of the crank the same? I was not able to get any number from the motor!!
Thanks.
boovuc
Over the years I have found that you almost have to measure that output shaft in person to know if it will be a good sub for a Wheelhorse. (Unless you know and trust the person's knowledge selling it).
You need inch and an eight diameter and the correct length and correct keyway to hold both the drive pulley and PTO.
Then you need to take into account the use of thrush bearings that can handle the stresses of the Wheelhorse setup verses what the original use of the motor it was speced for.
Gravely used a lot of "stub Shafts" on their tractors for their driveshaft/impellers. This wouldn't work but I don't know what is on the 812.
Good Luck
BooVuc
Mill Hall, PA
