etag1949 0 #1 Posted July 10, 2011 Bearings gone on inner pulley ate into the shaft Outer pulley bearing shot (falling apart) and pulley was nearly seized to the shaft after it sat for a week or so. loosened w/ PB blaster. Given there's zero rust on this, I'd rather refurb than replace. My first thought is to get an inner pulley with a flange, drill/thread a hole for a set screw and a shallow hole in the shaft to hold it in place and be done with it. Other ideas, how-to, links, sources to get the work done? If this plan gets a thumbs up from those with more experience at this than me (1st time WH owner & haven't worked in a shop where I could do this since 1970), I'm nearly 100% sure I have a source for parts. Thanks in advance Share this post Link to post Share on other sites
daveoman1966 3,881 #2 Posted July 10, 2011 I have a replacement... sending PM Share this post Link to post Share on other sites
