rdd52 0 #1 Posted July 9, 2011 hi folks i just picked up a 702 today the rear wheels are locked up i can't seem to get it neatrual we managed to get it in the truck but getting it out might be a little harder any ideas how to free it up? <_ Share this post Link to post Share on other sites
TT-(Moderator) 1,167 #2 Posted July 9, 2011 Does the shifter move? Has the tractor been sitting for a while? Did you happen to check the brake band? Make sure it's not rusted fast to the brake drum. Share this post Link to post Share on other sites
rdd52 0 #3 Posted July 9, 2011 the shifter does move and it does look like it has been sitting outside for awhile i will check the brake band and see what that looks like.thanks for the reply :woohoo: Share this post Link to post Share on other sites
rdd52 0 #4 Posted July 9, 2011 well i went out and checked it out the brake pedal was all the back and hit it with a rubber hammer until it freed up some it will need some lube. and i taped on the brake band that seemed to free it up i jacked up the rear axle and the tires turned freely but it looks like the left rear axle is out about a 1/2 inch farther then the right side the left side is shiny about 1/2 inch toward the center it does push in and out. Share this post Link to post Share on other sites
TT-(Moderator) 1,167 #5 Posted July 9, 2011 Look at the rear wheel hubs and make sure the end of the axle is flush with the face of the hub. You'll also want to make sure the hub setscrew is tight while you're there. Some lateral axle play is normal because of the retainer design. Radial play is what you don't want - which could indicate bad outer (needle) bearings. Share this post Link to post Share on other sites
rdd52 0 #6 Posted July 9, 2011 thank you i will check that out when i get it off the truck and start taking it apart. i have to wait until i can get some help and figure out were i'm going to put it.when i get it off my truck.it is another project. i will try to post some pictures when i get it off. :woohoo: Share this post Link to post Share on other sites
shorts 182 #7 Posted July 10, 2011 Just unload it at my house, I'll make room for it inside somewhere :woohoo: Share this post Link to post Share on other sites
rdd52 0 #8 Posted July 10, 2011 can i put my 701 there too? :woohoo: Share this post Link to post Share on other sites
shorts 182 #9 Posted July 11, 2011 sure, might as well, if i have to explain another garage, it might as well be a big one :woohoo: Share this post Link to post Share on other sites
