timmybobwatt
WIRING DIAGRAM NEEDED! E2-17K502 227-5 (1989)
timmybobwatt
Hi all,
Desperately trying to get my 227-5 up-and-running again.
Could someone please point me in the right direction for the wiring diagram?
I've been on the Toro site and the best I can come up with is a parts manual - not really specific enough!
Hope someone, somewhere can help!
Many thanks,
Tim
P.S - Hello!
timmybobwatt
Thanks ever so much for the speedy reply!
We have since acquired switch number 103991 as a replacement for this mower.
Someone has kindly cut the wires so we're pretty much going from scratch.
Am I right in thinking that '3' replaces 'G' or ground?
The rest:
A - Accessories
B - Battery
R - Rectifier
S - Start
M - Magneto
Any other input would be hugely appreciated, no matter how patronising it may appear. Even "run this wire to this etc" would be appreciated!
Thanks,
Tim
MikesRJ
I have no idea what "3" you are referring to.
What you have (103991) is displayed below and I don't see a "3".
timmybobwatt
Awesome - thanks so much for the help.
All running - but can't the ignition to stop the engine. Your thoughts?
MikesRJ
Check the ground from the switch to the frame. When the key switch is in the off position, terminals M and A should be grounded through the switch terminal G. If the ground from G to the machines frame is not good, the machine will not shut off.
