motofast 0 #1 Posted July 6, 2011 help what size would my deck be? charger 10 not sure the proper way to measure. want to buy new blades. thank you! Share this post Link to post Share on other sites
C-Series14 15 #2 Posted July 6, 2011 Measure the blades...tip - across center hole - to opposite tip. Share this post Link to post Share on other sites
tunahead72 2,558 #3 Posted July 7, 2011 To find out what mowers were available when your tractor was new, check out Toro's Product Information Center ( https://homeownersolutions.toro.com/portal/...duct_center/225 ). You'll have to enter your model number (1-0410 for a 1972 Charger 10 Automatic), then click the Search button. You'll see some general information on your tractor, then hit the Accessories button. It looks like only two sizes of mowers were made to fit originally, 36" (rear & side discharge) and 42" (side discharge). If you enter one of the model numbers they show for those mowers, you can then click on Look Up Parts to get a complete parts list and diagram (including blades). On the off chance that your deck isn't original, are you lucky enough to be able to read the ID tag on the deck? If not, do you have any photos? Might help somebody identify which one it is. And for an entertaining look at the whole "measuring your deck" problem , check this out: http://www.wheelhorseforum.com/index.php?showtopic=29420 Share this post Link to post Share on other sites
