geoff 0 #1 Posted July 4, 2011 A couple of years ago I purchased a used tiller attachment (model: 07-36TL03) for my WH 312-8. It was (and still is) my hopes to get it operational so I can help my grandfather (who's 95) plant his flower bulbs every year, without having to fight my old Montgomery Ward/Gilson walk-behind. Since then, I have been working on getting all of the necessary parts and fabricating pieces when needed. Aside from buying a belt, the big task now is to fix the two leaky seals on the tine shafts. I have a manual from one of the Yahoo groups, but it is for an older model (the pictures are very close). The parts I'm looking for specifically are as follows (or close to these): #6838 - Needle Bearing 1-1/4" ID x 1" (x2) #103118 - Seal 1-1/4" ID (x4, according to the manual) #6851 - Gasket Questions -- 1. Are these seals and bearings for the tine shafts still available through Toro? Is it something I could find generic at Tractor Supply (or similar)? 2. In regards to the gasket for the casing, is this still available or would I be better off just buying material and making my own? What about using the silicon stuff in lieu of the paper material? Or in conjunction...? 3. What gear oil is recommended for the Tiller attachments? (the color and consistency of what came out closely resembled chocolate milk) Any and all feedback is greatly appreciated. Thanks, Geoff - in MD Share this post Link to post Share on other sites
can whlvr 994 #2 Posted July 4, 2011 please dont quote me but i would think the case gasket would still be available and the seals and bearings at any decent sized bearing supply shop,napa auto parts(may have to order)and if you go to www.partstree.com and go into toro and then look around and i think uder tillers you will find your tiller,maybe if you put in the number that will help and it will take you to the parts breakdown,price and availability theres a toro site also but i dont know the address,could be www,toro and go into parts but i like parts tree,it works good Share this post Link to post Share on other sites
pfrederi 19,375 #3 Posted July 4, 2011 Some Tiller cross references Toro WH # Torrington Bearing# Bearings 6838 B-2016 1532 M-16121 1429 M-12121 1540 B-128 Shaft Seal Chicago Rawhide/SKF 103118 CR 12330 I use 90w gear Oil Share this post Link to post Share on other sites
Lost Pup 173 #4 Posted July 6, 2011 I used RTV and no gasket. No leaks so far. Tiller Rebuild Thread Share this post Link to post Share on other sites
KyBlue 655 #5 Posted July 11, 2011 I went through mine two years ago and swapped out all the seals. I bought mine through Toro directly. They had everything, and I too used RTV thou I went with the squeeze cheese Style (too lazy to squeeze the tube) Share this post Link to post Share on other sites
