dmoore 1,040 #1 Posted July 2, 2011 I want to pull my small utiility trailer with a 1 7/8 coupler...does anyone make a hitch that will install on the tractor to do this? Thanks! D Share this post Link to post Share on other sites
rmaynard 17,494 #2 Posted July 2, 2011 Does the ball need to be raised higher than the hitch that is already there? My B-100 had the hole drilled out to accommodate a regular 1-7/8" ball. Share this post Link to post Share on other sites
squonk 47,735 #3 Posted July 2, 2011 Here's the hitch on my 704. 1 Share this post Link to post Share on other sites
dmoore 1,040 #4 Posted July 3, 2011 Does the ball need to be raised higher than the hitch that is already there? My B-100 had the hole drilled out to accommodate a regular 1-7/8" ball. Yes it does......... Share this post Link to post Share on other sites
dmoore 1,040 #5 Posted July 3, 2011 SQUONK, That is what I need! Looks like it raises the ball up to the correct tounge level....I am guessing that hitch will fit most all uni-drive's? D Share this post Link to post Share on other sites
dmoore 1,040 #6 Posted July 3, 2011 I believe there was a thread about this a while back....just can't find it right now....D Share this post Link to post Share on other sites
SALTYWRIGHT 861 #7 Posted July 3, 2011 GO TO WHEEL HORSE HITCHES ON E-BAY. THERE SOME FOR SALE FOR THE FRONT AND BACK. IT IS BETTER ON THE FRONT SO YOU CAN SEE THE TRAILER. RUSS :woohoo: Share this post Link to post Share on other sites
tunahead72 2,640 #8 Posted July 3, 2011 I believe there was a thread about this a while back....just can't find it right now This one? http://www.wheelhorseforum.com/index.php?showtopic=27616 Share this post Link to post Share on other sites
WildHorses 442 #9 Posted July 3, 2011 My dad has an old 2" hitch ball that fits the hole in the standard hitch but he's had it for years and I have no idea where he got it or if they still make it. I'm looking for one myself btw Share this post Link to post Share on other sites
dmoore 1,040 #10 Posted July 3, 2011 I believe there was a thread about this a while back....just can't find it right now This one? http://www.wheelhorseforum.com/index.php?showtopic=27616 That's it! Thanks Ed! Share this post Link to post Share on other sites
tunahead72 2,640 #11 Posted March 17, 2012 I believe there was a thread about this a while back....just can't find it right now This one? http://www.wheelhors...showtopic=27616 That's it! Thanks Ed! Just a correction -- here's the current location of the thread I linked earlier: Share this post Link to post Share on other sites
Paul D. 26 #12 Posted March 17, 2012 I know most farm stores carry a 1 7/8 hitch that will fit in the standard Hole in the hitch. The family farm and home near me has them for $6.99. I can't say I have ever seen them for a 2" ball though it wouldn't be difficult to make a couple mods to get you there. If you didn't want to drill out the hole in the hitch you could make an adaptor Share this post Link to post Share on other sites
tunahead72 2,640 #13 Posted March 18, 2012 This may look like a semi-hijack, but it seems like a good place to ask... I may be looking at this wrong, and I need to check my measurements again carefully, so somebody please feel free to correct me. On my 310-8, and probably my C-105, the existing hole in the drawbar is just a bit over 1/2" diameter. The smallest shank diameter I've seen anywhere for a 1-7/8" ball is 5/8". I've seen references here to 1/2" diameter shanks for that size ball, but I've never actually seen one for sale anywhere -- maybe they truly just don't make them that size any more? I really don't want to drill my drawbar, but I will if it's absolutely necessary. I'm trying to keep this as simple and inexpensive as possible, and I don't think I have to raise the ball at all in my particular case. I confess, the only place I haven't looked extensively is eBay, it's on my to-do list. Does anybody know where to buy a 1-7/8" ball with a 1/2" shank diameter? Thanks! Share this post Link to post Share on other sites
smoreau 658 #14 Posted March 18, 2012 Look in the tractor section at TLC for a ball with a 1/2" bolt in it instead of a shank. That's what I used before building my 2" heavy duty hitch that I sell. Share this post Link to post Share on other sites
tunahead72 2,640 #15 Posted March 18, 2012 Scott, Thanks for the suggestion, but I'm feeling really dense right now. I've looked everywhere I can think of at TSC (I assume that's what you meant, not TLC), and I can't find the ball you're talking about. You want to sell me your old one? Or is it somehow possible to couple/reduce a 5/8" shank to a 1/2" bolt? Going to bed now, brain hurt. Share this post Link to post Share on other sites
Paul D. 26 #16 Posted March 18, 2012 The easiest way to make an extention would be to take a piece of 1/2 thick flat stock about 3" long and drill a 17/32 hole in one end of it and a 21/32 on the other end. Use a bolt and nut to bolt it to your hitch like a short extension sticking out the back and the take the 5/8 shaft ball and bolt and nut it into the 21/32 hole Share this post Link to post Share on other sites
Kelly 1,038 #17 Posted March 18, 2012 I use the ball from TSC it is a 5/8 shank, I just drill out the hitch, or use a die grinder to open the hole up, I also put the ball on tighten the nut by hand mark a spot right below the nut on the shank with a paint marker, remove the ball and drill a hole at the mark so I can put a cotter clip/hair pin clip in the hole, that way I can put the ball on with out tools and the nut can not back off with the clip there, 99% of the stuff I tow does not need the nut tightened up any more than by hand. Share this post Link to post Share on other sites
tunahead72 2,640 #18 Posted March 18, 2012 Excellent ideas, guys, thanks very much! :thanks: Share this post Link to post Share on other sites
can whlvr 994 #19 Posted March 19, 2012 you can get an insert for the ball,i think ive seen 3/4 down to 1/2, Share this post Link to post Share on other sites
kpinnc 18,853 #20 Posted March 20, 2012 If you add the ball on the drawbar hitch, a little reinforcement under the tranny is not a bad idea either. I've seen trannies with the bottom broken out because a heavy load was accidentally dropped onto the hitch. Just tacking a small "plate" out of 1/8 cold rolled is a big help: Share this post Link to post Share on other sites
