clintonnut 126 #1 Posted July 1, 2011 I need the part numbers for the wheel and bracket on the tensioner for the deck. I just can't quite read the numbers out on the online manuals. Heres a pic. Share this post Link to post Share on other sites
TT-(Moderator) 1,162 #2 Posted July 1, 2011 Toro & PartsTree both have a "zoom" button for the IPLs. If it's still not big enough (and you're running Windows) hold down the "Ctrl" key and use the "+" or "-" keys at the far right to expand or reduce the image size. Share this post Link to post Share on other sites
daveoman1966 3,841 #3 Posted July 1, 2011 Instead of fighting with that old style side-mount belt adjustment mechanism, why not up-grade to the front-mounted mule drive. It just has a knob on it to adjust and set the belt tension and is far less problem-ridden than these old-school systems. What's more, you use the same belt even. I've done this up-grade to (for) several old Raiders and Chargers. Here is a pic of a Raider 10 with the up-grade. for more details, contact me in an OFF-SITE email... my address is: daveoman@windstream.net Attached Image Share this post Link to post Share on other sites
TT-(Moderator) 1,162 #4 Posted July 1, 2011 OR........... you can see it ON-SITE here: http://www.wheelhorseforum.com/index.php?showtopic=2819 @Charlie: I figured out what you're looking for. 8174 is the bracket 6714 is the "roller" They are for the second version of that system like used on the 1968 - 1972 mowers. (better design than the 1966/67 models that had the roller mounted to the end of a special long "bolt" that fastened through the back hole of the speed hitch side plate) Share this post Link to post Share on other sites
clintonnut 126 #5 Posted July 2, 2011 Thanks Terry. I definately want to go sans the stud and using that post 1968 bracket. That wil work well. As you can see in the pic i smoothed the wheel riding surface so the wear bumps disappeared. It should work fine for .4 acres every 10 days. Charlie Share this post Link to post Share on other sites
