brooks60burb 0 #1 Posted June 28, 2011 hi everyone! Im restoring a suburban 400 it belonged to my late uncle. can anyone tell me the way the hood was supposed to be connected to the firwall in front. This one has 3/8 threaded rod need help bad obviously!!! lol :woohoo: Share this post Link to post Share on other sites
rmaynard 16,873 #2 Posted June 28, 2011 :woohoo: Glad to have you with us. I'm sure an answer to your question will be forthcoming. Post some pictures when you get a chance. Share this post Link to post Share on other sites
brooks60burb 0 #3 Posted June 28, 2011 Thanks glad to be here! make the show in PA? I went friday was my first wont be my last! Share this post Link to post Share on other sites
wallfish 19,324 #4 Posted June 28, 2011 :woohoo: A 400 would use two 1/4-20 bolts to hold the hood to the "ears" of the hoodstand (firewall) Share this post Link to post Share on other sites
brooks60burb 0 #5 Posted June 28, 2011 Wallfish thanks a lot!!! Im not sure i have these ears but i will double check. This had two holes drilled down through the hoodstand-firewall will nuts and washers on the 3/8 all thread. what to do if there are no ears!? :woohoo: Share this post Link to post Share on other sites
wallfish 19,324 #6 Posted June 28, 2011 Can you post some pics of your tractor? It would make things easier if we could see it. Here's a link to "Finding you way around Red Square". You should see a thread that explains how to post pics and lots of other useful stuff. The pic thing seems complicated but once you get it, it's fairly easy. http://www.wheelhorseforum.com/index.php?showforum=83 Here is a link to the 400s in the picture gallery here on RS. There should only be 2 bolts on the side that hold the hood to the stand and one down the bottom front that holds it to the frame. http://www.wheelhorseforum.com/index.php?showtopic=951 Share this post Link to post Share on other sites
Kelly 1,037 #7 Posted June 28, 2011 If you end up needing a firewall/steering support, I have one, from a 400 that was parted out. Share this post Link to post Share on other sites
